"Plot" from 3.5
For V8 Forum Members only, Please list rolling road & dyno posts in here please
NorthernBloke
"Plot" from 3.5
Post by NorthernBloke »
I finally, after 7 months, got round to taking the car back for final setup, jets and metering rods etc. and I'm very happy with the results.
The car's not running massive power, as you'd expect from a n/a 3.5, but it's pulling over 195lbft from 2,300rpm to 5,300rpm and with the rebuilt and regeared diff (full interleved LSD and CWP to 3.77:1 from 3.09:1) it's woken the car up :D
The "plot" shows the figures from the initial setup runs from May - Run 1 and the final setup from Dec - Run 2.
I'd be interested in your thoughts
Andy
Darkspeed
Post by Darkspeed »
Still increasing at 5500 - where did it stop?
4.5L V8 Ginetta G27
NorthernBloke
That's as far as we took it - we'll see where it stops when I go back for just a full power run :)
Andy
poo slinger
Post by poo slinger »
i am just changing from a 3.89 diff to a 3.09
although i got 13" wheels. hoping its going to change the way the car drives at speeds.
does any1 know of a rolling road that stocks parts for edelbrock 500 carbs?
i am in south lincolnshire / norfolk.
NorthernBloke
I had to supply the calibration kit for the carb as it's not a model the rolling road I went to deal with often - they're more used to twin 40s / 45s
Andy
poo slinger
calibration kit? i think my jets aren't right.
NorthernBloke
It's a kit which from Edelbrock which contains the jets, metering rods, springs etc. for the specific model of carb so the tuner can try the various combinations. Rich, who did mine down at Motoscope went through about 3 combinations before he was happy.
http://store.edelbrock.com/calibrationk ... carbs.aspx
Andy
poo slinger
thank you very much, these got everything i need?
they available from the uk?
NorthernBloke
Yep, should have mate - you can get em here
http://www.v8tuner.co.uk/product.php?id=105
Andy
That is a nice healthy power curve you must he very pleased. With the fueling sorted it is a really nice smothe curve, in a light car like the escort it must fly :D .
Very nice
NorthernBloke
I am very pleased, a proper progressive curve :)
It does go pretty well 8)
Andy
It would be interesting to see what happened with a bit more exhaust duration (say 8-10 degrees) and a slightly wider LSA on the cam, say another 4 degrees, I am assuming you have tubular headers and a ballance pipe. Just I think that would give you about 300-400 more revs before the torque curve started to roll off and make it roll off more slowley, it would just widen out the power curve without loosing anything off the bottom end of the curve.
Sorry at it again with the what ifs. There really is no need it looks pretty well spot on.
NorthernBloke
Hi Mike
It is running tubular manifolds but, at the moment, it's 4 into 1 each side with no balance pipe. I do have an X pipe to go in at some point, when I get time, and this should give a little more torque :) I'm hoping to have it done before a rolling road session I'm going to in April but we shall see.
Andy
Andy
I think when you add the X/ballance pipe you will see a further small gain across the whole range, I wouldn't do anything drastic for now, just small developments on the theme you have followed so far.
NorthernBloke
I had the car back on Sauturday just to re-check as I'd fitted new fuel pump, regulator and filter and it topped out at 204bhp but we were having a little bit of clutch slip so it is probably slightly more - in any case the torque is available immediately so the car pulls away quite well :)
Andy
Return to “Rolling Roads And Dyno's”
