Advice on fitting an LT77
Please excuse the banality of this, but I've never done it before.
I'm attempting to fit my LT77 to my RV8, and I'm in this position
Is there any advice on how to get it aligned easily? I've got it in gear so I can hopefully spin the input shaft to mate with the clutch, but getting it to the right location to do that seems a bit hit and miss of wiggling the crane around. Is there a better way to approach this?
Regards,
You need to make sure the clutch plate is centralised in the clutch - otherwise the spigot won't engage in the crank bush. The normal way is to use a pukka centralising tool which is a good fit to the bush and also the splines - a spare gearbox input shaft is perfect if you don't have the tool. You could make one up out of wood if you have the patience - the tool doesn't have splines, just a tight fit inside them.
However, since you've got easy access with the engine out, remove the box and look at the centre plate relative to the bush - and perhaps other round bits of the clutch, depending on design, and see it it looks lined up. Use one eye and get it central to the bush.
You could also slacken the clutch cover so it only just holds the driven plate. Fit the gearbox which will move the plate to the correct place. Very carefully remove the box keeping it level, and tighten the clutch cover to the correct figure.
Darkspeed
Post by Darkspeed »
Has this engine and box been together before?
4.5L V8 Ginetta G27
Not these particular ones. The bellhousing/gearbox came from my 3.5L, the engine is a 4.3 from a Griffith.
Darkspeed
Post by Darkspeed »
It looks pretty close together and if you have not checked the spigot bush may be for a T5 and not an LT77 - I have no idea if they are so different its just a guess.
scudderfish wrote:Not these particular ones. The bellhousing/gearbox came from my 3.5L, the engine is a 4.3 from a Griffith.
4.5L V8 Ginetta G27
harvey
Post by harvey »
scudderfish wrote:Is there a better/safer/more accurate way of holding the gearbox whilst I do this?
Dare I suggest with your hands? Even if you have to get someone to help you.
Darkspeed wrote:It looks pretty close together and if you have not checked the spigot bush may be for a T5 and not an LT77 - I have no idea if they are so different its just a guess.
I've put a new clutch and bush on anyway as it was all apart. My problem really is that with the gearbox dangling from the crane by straps, I can't position it very accurately. I'd be happier if I could get my load leveller (sat on top of the engine) fitted to it but there don't appear to be any convenient bolt holes. Is there a better/safer/more accurate way of holding the gearbox whilst I do this?
Regards,
If you are happy that the clutch is aligned properly and the spigot bush is the right one for the input shaft (and the clutch plate matches the input shaft spline pattern) then you should be able to fit it by hand with the engine sat securely.
With the box in gear you should be able to twist it to and fro to line up the splines. It does help if you have a mate on hand to twist the output shaft if required and also to get the first couple of bolts in once it slots in and you hold it in position.
JSF55
Post by JSF55 »
Get a couple of lengths of 3/8 unc thread bar or bolts with the heads cut off and screw them into the engine holes, use this too assist with lining it up
So thats where it went !
JSF55 wrote:Get a couple of lengths of 3/8 unc thread bar or bolts with the heads cut off and screw them into the engine holes, use this too assist with lining it up
Fabulous idea! Thanks :)
Just to follow up, I've got it fitted. The threaded rod acted as a good guide and after putting it in gear and wiggling the output shaft about a bit, it just slotted in :)
Denis247
Post by Denis247 »
Try mating them in the car, with the engine hanging from a beam and the gearbox balancing on a trolley jack !. That's fun.
conrod
Post by conrod »
I just refitted mine into my van, laying on my back, slid the gearbox on to my chest, heave it into place and put the bolts in, bit of grunting involved but wasn't that hard :D Third time I have done that, and I am not exactly a large bloke either! You guys need to harden up! :D
NorthernBloke
Post by NorthernBloke »
conrod wrote:I just refitted mine into my van, laying on my back, slid the gearbox on to my chest, heave it into place and put the bolts in, bit of grunting involved but wasn't that hard :D Third time I have done that, and I am not exactly a large bloke either! You guys need to harden up! :D
I did that with mine last time and after it wouldn't go in after five attempts I ran out of strength :lol:
So I went to grab a mate to help and would you believe it the f'in thing virtually fell in :x :roll:
Andy
conrod
Post by conrod »
Yeah I must admit, it took two or three attempts the last time after I ran out of strength :lol: Got the bugger in though! :D
