SD1 Vitesse Flapper conversion to hot wire
swight
Post by swight »
How easy is it to fit a 3.9 Hot wire engine into a SD1 Vitesse with the flapper system. What do I need to do to change the wiring system, i.e. do I need the loom from the Range Rover with the ecu. Thanks, Steve
badger
Post by badger »
Change complete system over - inlet manifold, pipework, airmeter, harness etc and fit a landrover discovery 3.5efi hotwire ecu as the 3.9 ecu will overfuel.
Badger.
www.roverv8engines.co.uk
3.5 hotwire?
when did that come out?????
and why will the 3.9 ecu over fuel???
i ran a complete 3.9 system and ecu on a 3.5 and it never overfuelled one bit.
swight
Post by swight »
Thanks for the replies. What I want to do is fit a complete 3.9 engine and components to my SD1, so what I need to know is how do I mate the hot wire loom to my sd1. Thanks, Steve
what i did was find the 5 pin plug on the sd1 efi loom, cut the plug off the flapper efi side, and wired the hot wire loo to the plug and connected it back to the car plug.
there are two wiring diagrams on th forum so you can cross reference what colour does what on the 3.5 and 3.9 looms,
landybob_v8
Post by landybob_v8 »
the late discoverys before the change to 3.9 had 3.5 on hotwire tony
v8's everywhere at least the one in the spare bedrooms gone now
mrs happy again
well i never knew that,
something else i have learnt. 8-)
