Distributor wiring?
Posted: Tue Nov 21, 2006 8:22 pm
by AndyS2
I've just finished putting a new V8 in my Range Rover and I've got 1 wire left that I can't remember where it conected to. It's a single green wire coming from the amplifier on the side of the distributor and it has a large eyelet on end. Anybody help me out, I'm dying to fire it up!!
Andy
Posted: Tue Nov 21, 2006 10:34 pm
by jrv8
Which terminal is it connected to on the amp ?
Jim
Posted: Thu Nov 23, 2006 6:26 pm
by AndyS2
On closer inspection it actually goes to a spade terminal just above the amp, here's a pic:-
Any ideas??
Posted: Thu Nov 23, 2006 7:01 pm
by softdash3.9
Hi Andy,
Nice to see you've got it in
the wire isn't for the oil pressure gauge to the left of the front cover or temp sensor?
Posted: Thu Nov 23, 2006 8:17 pm
by jrv8
Hi Andy,
That terminal is for an earth connection, (not always used) ,but the wire colour is normally black.
Jim
Posted: Thu Nov 23, 2006 10:59 pm
by AndyS2
Royston,
I thought that when I first saw it as it's the same type of connector but the oil pressure sender wire is built into the loom, this is a single wire.
I'll try earthing it and seeing what happens. Thanks for suggestions.
Andy
