Oil Temperature
Posted: Sat Apr 14, 2012 9:01 am
I'm trying to get this right in my head. I've been designing heat exchangers for a few years now, so I had a different view point during my last engine change
Some of the oil will be come out of the crank and will be above block temperature, but I wouldn't think by much. Some of it is coming off the piston underside, and it will be very hot. So I assume the oil temperature in the sump is a combination of both. (100 deg.c plus some higher).
Then the sump does some cooling (or not, depending install) so that the oil pump gets some quite hot thin oil. If the oil leaving the pump or the filter is measured to be too hot we fit an oil cooler. But how much effect does that have? I'm thinking that the engine block galleries heat the oil back up and that the flywheel main bearing probably gets oil at water jacket temperature?
I'm not doubting an oil cooler increases the oil pressure, as I used to run one myself
But I wonder how much is oil-cooler and how much is extra coolant for the bottom of the block?
So I'm coming round to the thought that the oil needs cooling before it enters the oil pump for best effect on oil pressure?
That maybe its better to fin the outside of the sump? Or, that an electric pump sucking oil from the sump, cooling it, and pumping back into the sump would be way better for back pressure than an 'in circuit' cooler. (probably easier to control as well)
[Which I suppose is part of what dry sump does, but I didn't want to make it a dry sump thread
