stevieturbo wrote:I'd have thought more power than that actually.
80Amps at 14Volts = 1120Watts
There are 746Watts per horsepower
So 80Amps at 14Volts = 1.501hp
Not enough to be worth worrying about!
You might well be right as those figures don't take into account any loses. It's really just a straight conversion from amps to watts then to HP (745.7 watts =1hp) . It won't be much more than that though.
Using a really modern alternator would be difficult as they are all ECU controlled now for fuel efficiency. Things like they charge less on acceleration and more on coasting/overrun. Even the 4.0 4.6 rovers had large alternators though, all the serp belt ones basically. They were 110A if I remember right. Not sure if you could drive a large alternator effectively without a serp belt right enough.
I have a self contained 100 amp unit on my SD1 EFI driven off the v belt. It's a Marelli A127 type with integral fan. More or less a direct replacement with an extra spacer to one of the original brackets. I do have a turnbuckle for adjustment as the original was a right fiddle to set.
When the alternator on my P6 packed up I had it rewound to deliver higher amperage. I can't remember how many it delivers, but it was significantly more than standard.
Any decent rewinding place would be able to wind it to deliver higher amps.
katanaman wrote:You might well be right as those figures don't take into account any loses. It's really just a straight conversion from amps to watts then to HP (745.7 watts =1hp) . It won't be much more than that though.
Hi Marki
In the old days they used to recon they could power 5hp through a standard V Belt
Things like Lawnmowers with a Brigs & Strattern 4.5 hp motor through a V belt working hard on thick grass held up for ages
Hi Marki
Perhaps, but a lawnmower wont see the same rpm's and change of rpm's than a car belt will.
this has wandered a bit :offtopic :lol:
Rossco
Moderator Gold
Moderator Gold
Post by Rossco »
Tony......lets admit it though, most lawnmowers have done more miles than the Cappa in the last 2 years
:lol:
r2d2hp
Post by r2d2hp »
think my chainsaw has vibrated further :-)
Rossco wrote:Tony......lets admit it though, most lawnmowers have done more miles than the Cappa in the last 2 years
:lol:
Ouch!!! :)
r2d2hp wrote:think my chainsaw has vibrated further :-)
Double OUCH !!! :)
Come on guys! Coops need some support here :)
sorry :oops:
Double OUCH !!! :)
Easily found on line
http://www.amazon.co.uk/s/?ie=UTF8&keyw ... fbmkc45e_b
:lol: :lol: :lol: :lol:
Darkspeed
Post by Darkspeed »
Sorry for still wandering
That assumes no heat produced, no running of the cooling fan required. and no mechanical losses in the system. no belt frictional / heat losses etc.
Expect the system to no more than 40% EFF. maximum and efficiency dropping with RPM.
Just think of the effort required just to spin the alternator and its fan at 10,000 rpm without it actually being connected to anything.
I would say more like 4-5HP at 6000RPM and all losses are worth worrying about. Its a 1% loss even with a 500BHP motor
4.5L V8 Ginetta G27
I agree there will be losses but 4-5 HP? That would mean your your using 2.5-3.5 to get 1.5 worth of power. I really doubt that, even a screw supercharger isn't that inefficient and they are fairly poor.
Anyway we better get back on topic before Tony breaks out the big sticks :lol:
