Page 51 of 79
Posted: Tue Mar 05, 2013 9:38 am
I had thought about similar myself, just not really sure what sort of filter to use. How long it might last etc.
The actual oil/air separator section would need to be very good before the filter.
I actually bought a cheap LPG inline filter to look at. It had 16mm hosetails on the end and a paper element and alloy body. It may be suitable, although something larger diameter would have been nice.
Never bothered using it, I just have a small K&N filter on the catch tank as a breather.
Only downside with mine really, is it seems to gather huge amounts of condensation. I think it's because it's mounting so far away from the engine and long hose runs. But really not sure. It does gather some amount of crap though. That said, even when I had a smaller one mounted close to the engine, it gathered some crap too.
That's with a cold start or a normal 90degC stat in the engine. My old RV8 was never as bad.
Posted: Tue Mar 05, 2013 3:27 pm
by Coops
we have some flat panel paper elements that are used on the mowers at work,
that has an oil breather system on them too, we also have filter boxes for them to go in
may nick one and see how long they last,
Posted: Tue Mar 05, 2013 3:35 pm
by Coops
Posted: Tue Mar 05, 2013 3:40 pm
by Coops
Posted: Tue Mar 05, 2013 6:17 pm
The Pipercross one might be suitable....although by their reckoning about all the hose sizes it does, sounds like it's only 13mm and the sleeve it for bigger hoses.
This was the type of thing I bought but didnt use
http://www.ebay.co.uk/itm/LPG-AUTOGAS-F ... 43b8d679f1
At least the hole is a reasonable size.
I'd say that when mounting any such filter it would need to go from catch can into the bottom of the filter, then the top side would go to the intake/air filter plumbing.
Again, so that any moisture, oil or whatever that did get trapped, would naturally run back into the main tank.
Posted: Tue Mar 05, 2013 6:44 pm
by Coops
this a disposable filter? or a reuseable one mate?
Posted: Tue Mar 05, 2013 6:49 pm
I'd say they're disposable. Given what I'm suggesting they're going to use them for....I'd say they'd last a very very long time.
It isnt to filter as such, more just an additional oil/air separator to ensure nothing gets into the intake. And actual airflow through it would be fairly low.
Posted: Tue Mar 05, 2013 6:55 pm
by Coops
ill get one and have a look,
Posted: Sat Mar 09, 2013 12:35 pm
by Coops
install has come to a halt for a bit,
going to take a couple of weeks for Roose to sort the hoses out.
Posted: Wed Apr 03, 2013 9:55 pm
by Coops
Update,
Roose forgot to do the hose order,
so we have been put back yet another few weeks,
Posted: Sat May 11, 2013 1:43 pm
by Coops
all hoses here now,
But due to the landlord serving us notice everything has been put on hold,
we are now at the new house, BUT no garage or base yet,
I have 1 week to get the old garage down and moved over to the new house, (any takers
once this is done we can get a new base put down, get the garage back up and move the capri over to here then and start work again,
Posted: Tue Jun 18, 2013 4:35 pm
by JP.
Any updates mate???
Posted: Tue Jun 18, 2013 5:43 pm
by Coops
Hi Mate,
garage should be finished this week coming,
So by the weekend, fingers crossed the car will be home at last and i can start again on fitting the charger etc,
Posted: Mon Jun 24, 2013 3:30 pm
by Coops
have started working on the install again,
and it looks like the air filter is going to have to go through the inner wing,
Posted: Mon Jun 24, 2013 3:41 pm
by Rossco
Tony
Is there no option to turn the plenum round to face the other way?
Would give you more space
