Page 6 of 13
RV8 engine numbers
Posted: Tue Feb 16, 2010 8:52 am
by irony
I have two RV8's in my garage and I need to find out some details for the them to satisfy the IVA man. Does anyone know what details I will need or do you guys/gals have any references to the following engines
17005781B
S10A44028
Thanks muchly
Posted: Tue Feb 16, 2010 1:50 pm
by katanaman
17D00001A/B R.R CarbpulsairMan 9.35:1cr 1983-85 I think what you have as a 0 will actually be a D
second one at a guess is a Morgan 3.5
Posted: Tue Feb 16, 2010 1:53 pm
by irony
katanaman wrote:17D00001A/B R.R CarbpulsairMan 9.35:1cr 1983-85 I think what you have as a 0 will actually be a D
Stupid me I did make a typo there. Can anyone give me details on a morgan, will morgan be able to help me? Thanks for the info.
Posted: Sat Mar 06, 2010 10:40 am
by alastair_vns
Hi I have 2 symbols on each side of my numbers what are they? they look like wheels.
thanks Alastair
Posted: Sat Mar 06, 2010 2:07 pm
by Darkspeed
Without a photo I am only guessing - there are only two round identifications that I am aware of
If its cast into the block then its the date identifier - year in the middle and then an arrow showing the month on the clock face around the outside.
If its stamped then then only one I have seen is the BL Symbol
alastair_vns wrote:Hi I have 2 symbols on each side of my numbers what are they? they look like wheels.
thanks Alastair
Posted: Sat Mar 06, 2010 3:40 pm
by alastair_vns
Hi thats the symbols the numbers inbetween the 2 symbols are badly scratched tho so cant find what engine it is. Is there away of telling what engine it is from the exhaust port sizes? thanks
Posted: Sat Mar 06, 2010 7:43 pm
by katanaman
alastair_vns wrote:Hi thats the symbols the numbers inbetween the 2 symbols are badly scratched tho so cant find what engine it is. Is there away of telling what engine it is from the exhaust port sizes? thanks
I am afraid not, the best you could do is possibly tell whether it is a P6 or not but even that is doubtful. Without an engine number your kinda stuck with what the engine capacity is and a few other ways to narrow it down to whether it is a 4x4, P6 lump if its a 3.5
Any one know what this is out of?
Posted: Sat Apr 10, 2010 9:48 pm
by stagcar
Just wondering what the engine in the manta was out of.
Looks to have a p6 timing case with p6 rockercovers and a sd1 front pulley
I thought it was p6 but i think it may be sd1 the number is 10a37187
Can't seems to see it in the list.
Derek
Posted: Sun Apr 11, 2010 12:00 pm
by katanaman
its in the list under SD1 manual
Posted: Sun Apr 11, 2010 3:56 pm
by stagcar
katanaman wrote:its in the list under SD1 manual
cool thanks marki your a star! better than the old p6 I thought it was then.
Derek
Posted: Mon Jul 05, 2010 10:02 pm
by sven410
I had a look on one of the RV8 engines I have kicking around today and wonders if anyone can help med with identifying it...
it has 9,35:1 CR
enginenumber under the left head says 56D22214A
On the engineblocks side, behind the starter engine I found these WYF15 and HRC2411 and behind the flywheel it is a letter J
Under the rockercovers I find the numbers HRC 2479 and I4
it also has bolts for the mains through the sides of the engine block and some kind of mountingbracket welded in behind the flywheel on the opposite of the starter engine
the heads also uses less bolts than the other engines I have.
Thanks guys
Sven
Posted: Tue Jul 06, 2010 8:16 am
Sure it's not 46D.....A?
Posted: Tue Jul 06, 2010 4:37 pm
by sven410
I am pretty sure about that, but can double check next time I am at the workshop..
Posted: Thu Jul 08, 2010 9:05 pm
by sven410
found out what that engine was yesterday...
the 56D engine is a 1999-2000 LR discoveryII engine...
thanks for the reply:)
Sven
Posted: Sun Jul 11, 2010 12:48 pm
by NorthernBloke
I picked up a load of spares (abandoned project) last week and on checking the block the number is S48300118D which doesn't appear on the list
Any ideas anyone?
