1982 SD1
V8 Only Please,
ged
Post by ged »
Robrover wrote:Looks great Ged, which cam did you change over to? Ever had it on a dyno?
Thanks Robrover. :D
Cam's a stump puller, but with the rockers I get approx 0.020" more lift. I did want a Tornado but they aren't available at the moment. However I'm pleased with the outcome (for now). It pulls like a train & I have to keep a careful eye on the revs as it's easy to rev past 6000rpm.
As for rolling roads no I haven't.
I'm defo old school so I read the plugs for mixture, same with the timing (see how it pulls at different amounts of advance without pinking & how willing it is to rev).
Regards Ged
ged
Post by ged »
bigaldart wrote:Ged,
Looks great, would love to know more about the rocker gear, construction, materials, bearings used, any chance of making another set :)
I would really like to get some insight, might even consider making some ourselves.
Keep up the good work
Alan
Thanks AL,
Much appreciated! :D
As for the rest leave it with me & I'll I let you know.
Regards Ged
Jono FD3
Post by Jono FD3 »
top work matey, love the rocker setup you have done..... I enjoy tinkering and fabricating things, but that is way out my league!!
jono
A very nice Job Ged!!
Well done mate :)
ged
Post by ged »
Thank's fella's
Regards Ged
ged
Re: 1982 SD1
Post by ged »
I've not updated this for a while.
Car's been sat unloved in the garage for over 4 years. Anyway it's been long over due to go back on the road.
All fluids have been changed but it's still covered in dust including the inside because I left the window open. :roll:
I'll get it cleaned up & MoT'd in the next 2 weeks. Anyway here's a short video.
Image20190414_132718 by Ged Sant, on Flickr
Muscle-Manta
Re: 1982 SD1
Post by Muscle-Manta »
Jed, Looking at your rear disc conversion. What parts did you use? any pic's of how you carried it out please?
Thanks,
Paul.
ged
Re: 1982 SD1
Post by ged »
Paul,
I used Sierra Cosworth vented discs & calipers on the rear however it wasn't a straight forward fit.
I had to machine the axle flange so the disc would fit over it.
The mounting holes in the discs had to be slotted to suit the Rover PCD & the spigot enlarged.
I made the caliper mounts from scratch with the correct offset to align the caliper with the disc.
I had to make my own handbrake cable.
At the same time you need to up grade your front brakes!
I used 305mm vented discs from an XJS with the Rover 4 pot calipers. The calipers were mounted on adaptors which spaced them out from the centre & rotated them so that the holes didn't clash.
This will not fit inside a Rover Vitesse 15" wheel.
It was a lot of work but I enjoyed the challenge.
The end result was really good brakes, that just stop you fast with no nasty habits.
Some photos below.
Ged
ImageCALIPERMOUNTS by Ged Sant, on Flickr
ImageFRONTDISCS1 by Ged Sant, on Flickr
ImageREARDISC1 by Ged Sant, on Flickr
Re: 1982 SD1
To avoid having to modify the hubs on the rear axle, I found a Maserati disc which fitted over it. Here's a pc on the slave axle I used to sort things out. The PDC was very different, so the disc did need work.
I have an XJS front brake conversion which fits the original 15" wheels.
ged
Re: 1982 SD1
Post by ged »
DaveEFI wrote: Sat May 18, 2019 10:01 am To avoid having to modify the hubs on the rear axle, I found a Maserati disc which fitted over it. Here's a pc on the slave axle I used to sort things out. The PDC was very different, so the disc did need work.
Did you ever finish it?
ged
Re: 1982 SD1
Post by ged »
I looked into fitting dual exhausts when I did the bodywork in 2008. I decided at the time it was too much hassle as I would have had to remove the fuel tank & fit a fuel cell in the boot to achieve what I wanted. As a compromise I channelled the boot floor so that I could fit a duel 3" tail pipe & raise it up. I always thought the SD1's exhaust was a design after thought & never looked right. It's only taken 11 years for me to get around to finishing it!
Image20190526_193127 by Ged Sant, on Flickr
Muscle-Manta
Re: 1982 SD1
Thanks for the photos and description Jed. Sorry it's taken me so long to get back not been on the forum for a while. Love the look of the exhaust! very neat.
Re: 1982 SD1
The cranked over exhaust is to stop fumes being sucked into the car. Anything else is likely to do it so some extent.
ged
Re: 1982 SD1
Post by ged »
DaveEFI wrote: Wed Jun 12, 2019 9:50 am The cranked over exhaust is to stop fumes being sucked into the car. Anything else is likely to do it so some extent.
The only time I've ever had a problem with fumes is when the flap in the tail gate was not fitted correctly. I have zero ingress of fumes with this tail pipe.
I know you're a serial forum poster & you fancy yourself as an expert on all subjects Dave, but If you have nothing positive to say then kindly keep your unsubstantiated opinions to yourself.
Re: 1982 SD1
Thank you for your kind words.
if you check the SD1 forum, you'll find plenty evidence of fumes entering the car with non standard exhausts. With all the flaps in the tailgate present and correct, and the seals too. One such only last week.
Perhaps you never wondered why Rover chose to fit that odd looking tailpipe?
Return to “Your Cars”
