Page 5 of 9
Posted: Wed May 09, 2007 11:06 pm
by kev_the_mole
Stop press....
breadboard is a P.O.S. and I can't solder for sh1t either. A proper circuit board is needed and 5 hours of head scratching later we had a professional(?) looking 2-layer LED and resistor layout and the first tracks partially laid in.
:( :( :( in-line resistors make the board too crowded so I'll have to change them to surface mount. Onwards and upwards :lol: :lol: :lol:
Posted: Thu May 10, 2007 1:08 pm
I suggest that you use 0805 surface mount on the rear of the board, and through hole leds mounted from the front. That way (assuming you can track it) you'll only need one side with tracks on it.
You'll need a fine tipped soldering iron, tweezers and a microscope to solder it though, and if you can't solder for sh1t you might want to find a mate to do it!! Plumbers solder and a blowlamp just don't cut it.
Posted: Thu May 10, 2007 3:21 pm
by kev_the_mole
...soooooo what you're saying is the tig welder with fine wire is still no good :wink: :wink: :wink:
actually I have an electronics geek mate who will do the job in exchange for Weston's Old Rosie Cider (8%). But he's got to do the soldering before he does the drinking! :lol: :lol: :lol:
Posted: Fri May 11, 2007 8:05 am
I'd give him the Old Rosie first for a chuckle!
Posted: Sat May 19, 2007 11:10 pm
by kev_the_mole
Eeeehup!
after breadboards, LEDs, circuit boards and cider loving leccy geeks I found these beauties lurking in a Harley Davidson accessory site. Outer ring amber, inner rings 2 mode side and stop. Unfortunately they wouldn't fit the original glass lenses so I turned up some acrylic replacements. Couldn't be asked to make them optically perfect by polishing for hours though.
Posted: Sat May 19, 2007 11:13 pm
by kev_the_mole
....and the finished result looking IMHO not too shabby :shock: :shock: :shock:
Posted: Sat May 19, 2007 11:21 pm
by ihatesissycars
Yeah mush, they look cool geez!
:wink:
Posted: Sun May 20, 2007 3:22 pm
by kev_the_mole
Hmmmm....
I last saw a pair of those on the back of a dodgem car. So understated :D :D :D
Posted: Thu May 24, 2007 9:48 pm
by kev_the_mole
......wooooo the fleabay MX5 seats are here at last :D :D :D
Posted: Thu May 24, 2007 9:58 pm
by kev_the_mole
...but we had to mod the rollcage so the seats could give enough leg room.
The crossbrace was moved off from one side of the cage to the wheel arch.
Posted: Thu May 24, 2007 10:09 pm
by kev_the_mole
.....and the dash is finished :D :D :D
until I decide to change it of course :shock: :shock: :shock:
Posted: Thu May 24, 2007 10:16 pm
by kev_the_mole
.....but it looks a bit like a 4x4 until the springs settle
Posted: Thu May 24, 2007 10:22 pm
by sowen
Good to see you've found some seats that fit in there and look good too, just waiting for a pic of them in there now :wink:
Posted: Fri May 25, 2007 7:49 am
Are those dash switches going to be OK for the SVA test? or don't you need one of those?
Posted: Fri May 25, 2007 9:56 am
by kev_the_mole
Chris,
thanks for the concern but in my best comic french voice "I spit on the SVA test" :lol: :lol: :lol:
Luckily the car is exempt (so far)
