My V8 Sierra project ..... maybe I will finish this one !
You're certainly dedicated !!
It took me near 9 years before I took the dash or carpet out of mine lol. And that was mostly to fix the heater
Mark
Post by Mark »
Getting bored now ...
Shopping time :D
Morrisons vinegar 13p a bottle
A few weeks soaking with a quick wire brush once a week has woked wonders.
How much effort did that require ?
I seen on another forum where a guy put his old brake discs into something. I think it was coke, and the difference after soaking was pretty amazing.
I did try with some cheap tesco coke and it did sweet FA lol
Is vinegar a better choice ? Or original coke maybe ?
I took to my front hubs with a grinder/flap wheel to clean and smooth them. Was bored one day ! Didnt take long either.
Wire knot wheel in a grinder is a good job too, albeit dangerous.
And is that the entire underside stripped to bare metal ??? patience of a saint ! lol
Mark
Post by Mark »
Not too much effort at all, just patience !
I've probably spent around half an hour with the wire brush in total so far on the hubs.
The underside I have spent a scary amount of time on :shock:
patience is something I lack lol
You can also use a molasses solution to strip away rust from steel. It takes a while (weeks) but if you have the space and time, it's a cheap effective way of doing it.
I'll guess it smell better than the vinegar, too.....
http://www.youtube.com/watch?v=KZCFcxf5IBw
http://www.youtube.com/watch?v=8-gBAjEga1s
OK
that is imressive.
I think I am going to try this with a pair of brake calipers!
So where do we buy Molasses ?
terziakis
Post by terziakis »
I have used citric acid to clear rust away, water + few spoons citric acid to bucket, and parts in, couple days later parts are clean, may need little brushing.
Here in Finland you can buy that citric acid from agricultural stores (I don't know is it right word).
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Oxalyic acid is also very good for cleaning up metal.
We use it to clean stainless up and it works a treat.
P
Is that readily available ? Is that what it would be used for ?
Molasses is an ingredient in some animal feeds, so your local farmers' suppliers should have it or at least know where you can get it.
gelmonkey
Post by gelmonkey »
stevieturbo wrote:Is that readily available ? Is that what it would be used for ?
Whilst you can no longer buy it over the counter at your local chemists it is available through companies like Interlabs.
I dont know exactly what its main usage is but it does work very well on removing rusty marks,cleaning metals and getting rid of stains in gel coat.
P
my Dad used to use domestic heating system flushing liquid as a general pickleing liquid for steel and copper, used to work a treat. Better than battery acid, it would remove virtually any gunge, scale after heat treating.
Best regrads
Depending on exactly what that is, you should keep it far away from the shiny bits as it will corrode stainless steel if it is this stuff.....
http://www.tergo.co.nz/Tech%20Data/HTML ... salts.html
