1982 SD1
V8 Only Please,
ged
Post by ged »
Well my cars been back on the road for a week now although I couldn't get an MOT test done until Friday. For some strange reason I had 45 miles on the trip meter. :lol: Anyway I went for a drive today (about thirty miles) & all seems ok. The newly rebuilt gearbox was tight at first but seems to be settling in. I just have to be patient running it in again, something I've never enjoyed doing. I'm hoping this is the last bit of bad luck for this year but if not as I always say, S*** happens deal with it!
Regards Ged.
Muscle-Manta
Post by Muscle-Manta »
Good to know your all sorted Ged. If you fancy a drive out for a meet sometime let me know.
Paul.
glad your all sorted now mate,
ged
Post by ged »
Thanks fella's,
I'll post some pic's when I get my usb port working. :roll:
ged
Post by ged »
usb working now, so here's a few pic's.
Engine freshly painted
Gearbox with locking bar
DIY heater pipe :lol:
Home at last
Billet alternator pulley & fan
Billet water pump & p/s pump pullies
Home made baffle
Some of the old gearbox parts with the pullers.
Bradham
Post by Bradham »
Think you realy love your car, because haven't seen that good looking for years!
bones
Post by bones »
i missed this post :? . looking good young sir, :D rich
ged
Post by ged »
Hi All,
I haven't updated this for a while so here's a few pic's. :D
I've just finished making & fitting these.
Also a short vid of it running
Regards Ged
All you need now is decent ignition and injection. ;-)
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Ged
That really does look the Yak's knackers mate.
Now drive the tyres off it :D
P
ged
Post by ged »
DaveEFI wrote:All you need now is decent ignition and injection. ;-)
Want a race?
ged
Post by ged »
gelmonkey wrote:Hi Ged
P
Hi Paul,
Cheers mate & I will. :D
ged
Post by ged »
Well I've been busy over the last month or so.
The pinion oil seal decided to leak & after spotting grease behind the extension housing mud shield I flipped the seal off the bearing to find the oil had washed all the grease out. So new seal & bearing. I dropped the back axle so I could give everything the once over.
Ready to go back in.
Also decided to refurbish the gearbox extension housing. I stripped it & replaced the split bushes on the shaft then made a set of poly bushes.
A huge improvement in shifting! Much more precise.
Next on the list was the sump was leaking due to grounding it after reversing off the MOT ramps. So new gasket & repaint.
Then a cam change.
All back together now & nice to drive.
Regards Ged.
Robrover
Post by Robrover »
Looks great Ged, which cam did you change over to? Ever had it on a dyno?
bigaldart
Post by bigaldart »
Ged,
Looks great, would love to know more about the rocker gear, construction, materials, bearings used, any chance of making another set :)
I would really like to get some insight, might even consider making some ourselves.
Keep up the good work
Alan
Return to “Your Cars”
