9.8mmIan Anderson wrote:Dash 6 = 6/16 inch = 3/8 inch =8mm
braided hose and fittings for fuel system.
i did but when i checked on line, couldn't find much info on fittings and hose.
Hellstevieturbo wrote:9.8mmIan Anderson wrote:Dash 6 = 6/16 inch = 3/8 inch =8mm
That was a good typo on my part
But worth pointing out the dash number is always sixteenths of an inch
Tony
Try
http://www.thinkauto.com/acatalog/intro.html
3 sections on hose and fittings
Please remember just becase it is braided does not mean it is better than non braided. The rubber in both perishes at about the same rate and needs replaced about every 5 years. But the stainless makes it very Bling!
IAn
Try
IAn
Tony
They are in Housnlow / Brentford / Syon Park area. I pass there regular. If you order any stuff I can collect so you can pick up from me if it helps.
Perry
Perry
right i need to get this sorted ASAP as this is going to hold the car up in the next few weeks,
what would you recomend?
looked at think auto
and now up for some help/advice
remembering i need m12x1.5 and m14x1.5 adaptors for the fuel pump and filter.
cheers guys.
cheers guys.
Phone Think Auto
Ask what they suggest and they will give pretty fair advice.
If you know how long you need the hoses they can also make up to correct lingth with crimped ends and bends as you need
They reallyare helpful
just a thought,
is there any adaptors to go from nylon to braided etc,
as the the car was running 10mmOD nylon pipe from pump tp filter,
the reason for the change was all the horrid joiners we used to mate it all up,
but if there are adaptors to change to say braided i can then keep cost down,
have most of the parts now sorted
after one last part -6 x M12x1 adaptor
this is for the hotwire fuel rail
i got the m12 x1.5's coming stevie for the pump and filter,
been told the actually fuel rail fitting for the fuel line is M12x1
unless some one knows different?
failing that im going to have to cut the o/e fitting off and then tig weld on a -6 bung to the fuel rail.
i am now sorted at last
the parts arrived from www.Torques.co.uk today
have a -6 weld on bung as well as another m14x1.5x-6 which will try and turn down in the lathe and cut a new m12x1 thread onto,
