Ceramic coated exhaust
Richard P6
Post by Richard P6 »
crayefish wrote:As for warm feet syndrome... I wish I had it.
Imagine the scenario of running a tuned P6 (which overheat in stock form) on a hot day in a traffic jam in Whitby. Lots of people admiring the car and its getting very hot. My only way out is to put the heater on and open the windows in a bid to cool it down a bit.
My feet, which were already hot because of the proximity of the exhaust, now start to melt.
I had to take my boots off in a different room!! :shock:
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
YEAH and don't we know how whiffy your plates were!
Smelt em down here :lol:
If your feet are getting really hot how about putting some adhesive heat sheild on the inside of the trans tunnel?
I bought mine from Summit and it is good kit.
As a cheap alternative and dont laugh, use some bacofoil with the shiney side to the metal as a heat barrier.You can fix it in place with gaffer tape or similar.
I have done the rear section of my cabin with that and it does seem to work well even though the car is just sat in the garage running.
My exhausts run very close to the floor and the radiated heat goes straight up (obviously) and the floor in the rear is always cool.
As for Ians hot shoulder syndrome how about a bacofoil t shirt?
Suit you sir :lol:
gelmonkey wrote: As for Ians hot shoulder syndrome how about a bacofoil t shirt?
Suit you sir :lol:
I could do that :lol:
So long as it does not clash with my tin foil hat used to stop "big brother" bombarding by brain with radio waves!
gelmonkey
Post by gelmonkey »
So that is YOU in the Dukes of Hazzard then Ian :lol: :lol: :lol: :lol: :lol:
Do you have a heat sheild/bulkhead in the GT40?
You must have.
What do you have as a heat sink?
Me and Daisy? Sounds like fun but not me!
Bulkhead between me and motor is about 1/8th inch fiberglass
No the is no heatshield - but Ihave thought about fitting it but that would be a motor and gearbox out job - naaah I like driving it too much to worry about the heat and after all the sauna helps keep my weight down (not)
gelmonkey
Post by gelmonkey »
Do you mind if I send you a PM ?
Dont want to clog this thread up.
Richard P6
gelmonkey wrote:YEAH and don't we know how whiffy your plates were!
Cheeky Monkey!! :shock:
gelmonkey wrote:If your feet are getting really hot how about putting some adhesive heat sheild on the inside of the trans tunnel?
The O/S pipe was too close to the tunnel to get anything in there, so the best bet, considering the condition of the rest of the system, was to have a new system built - properly. (£460 inc vat)
The headers and front section will be ceramic coated, but I will probably get a heat shield for the rear sections if needed.
Pics when I get 'em
gelmonkey
Post by gelmonkey »
Richard
I meant put the bacofoil under the carpet not up under the trans tunnel.
I did n't explain myself properly.
Aologies and i will go and set on the naughty step for the rest of the day. :lol:
topcatcustom
Post by topcatcustom »
Dont forget (I'm taking an educated guess here) that if you ceramic coat the front sections then the rear section (uncoated) will be hotter then it was before, as the gas temperature will be much higher.
TC
Richard P6
gelmonkey wrote:Richard
I will be using some of this - http://www.merlinmotorsport.co.uk/p748/ ... _info.html where necessarry. The rear box is quite close to the side of the boot, so with a bit of patience and a bit of detailed work, I can sort this problem once and for all.
topcatproduction wrote:Dont forget (I'm taking an educated guess here) that if you ceramic coat the front sections then the rear section (uncoated) will be hotter then it was before, as the gas temperature will be much higher.
I thought that and did ask this question in my original post. The straight through silencers will make a slight difference as the hot gasses are out and gone a little quicker keeping the whole system that bit cooler. Also the original manifolds held the heat in better than the stainless ones so I am only going back to original by ceramic coating the manifolds, and with careful use of the above heat insulation I can do the job properly and stop the problems.
It's bound to work :D
crayefish
Post by crayefish »
Richard P6 wrote:I will be using some of this - http://www.merlinmotorsport.co.uk/p748/ ... _info.html where necessarry. The rear box is quite close to the side of the boot, so with a bit of patience and a bit of detailed work, I can sort this problem once and for all.
That stuff is quite good. we used to use it on the rear bulk head and fuel tank on our old Formula car as the exhaust manifolds were about 2" from the fuel tank. that and some glass fibre tape round the manifolds and it used to stay prety cool.
only trouble is that the glass fibre is a bit of a bugger to glue to stuff. for small sections you can use hot melt glue (as long as the temps arent extreme) but for bigger sections we found epoxy worked best.... only trouble is it aint too cheap and one its on its on :shock:
the hot melt glue could be taken off fairly easily however
Zander
Richard P6
Cheers Crayefish
I actually own a specialist adhesive company :D
Bonding it on will not be a problem, but thanks anyway
I would probably go for a high heat Contact adhesive - possibly a spray version. I do have one which will take 160C, or to make things easier, I have an aersol adhesive which will take 100C in a low stress application. If you need higher, then a silicone gasket adhesive/adhesive would be best, easy to remove if needed and a heat resistance of 285C.
Richard
crayefish
Post by crayefish »
Richard P6 wrote:Cheers Crayefish
Richard
Looks like bonding wont be a prob then. :D
We tried contact adhesive, but found the corners and edges came loose fairly quickly. even on the stuff that wasnt high heat. maybe it was the stuff we used, but in the end we though sod it and either used poxy resin or used hot melt
Zander
gelmonkey
Post by gelmonkey »
Richard
Do you have a company website?I sometimes have need for specialist adhesives but struggle sometimes to find a company, let alone someone who has more than an ameobic knowledge of the products they are selling to answer questions or give advice.
Cheeky monkey aka Gelmonkey aka Paul :)
topcatcustom
Likewise!
TC
