Frankencarlton
That the 6L with the really good heads isn't it?
What Class/classes are you thinking of running in?
JJMclure
Post by JJMclure »
It's got the 317 castings on it which are pretty good as standard, I like the idea of the l92 / ls3 rectangle heads but it tends to get a bit pricey once you add the new manifold and rocker arms into it. As to a class it would be rwyb or outlaw street at most
don't nibble on the barrel, pull the trigger!
JJMclure
Post by JJMclure »
cleaned up the heads with a hot wash at bobharman.com then I scraped the leftover carbon off and jet washed them. I put new stem seals in and lapped the valves in
Image[/img]ImageImageImage
Great news to see some more progress mate :)
JJMclure
Post by JJMclure »
me trying to get the motor mount plates in
Image[/URL][/img]
Image[/URL][/img]
i detected roughly a 3 degree incline toward the rear on the front mount tubes so now I am trying to 'degree' the mid plate and cut tube to tack in, i'm wondering if it would be easier to have the plates bolted to the engine and have it supported in the chassis?
if you bolt the engine between the plates you can use the main cap bolt holes to mount a flat piece of metal across the crank center line and then use a cheep laser level on it's tripod to fire an aligning dot at the axle center (or three degrees bellow it), it is then very easy to get everything lined up that way. This is how I did my engine lined up in the dragster and it is easy to get it lined up in a way you feel confident with.
best regards
JJMclure
Post by JJMclure »
I hope to use the truck manifolds my engine came with to keep the costs down, ha ha, so I slapped my front plate on with a head to see where the exhaust manifolds were going, as it turns out they would be exiting in the mid plate so I am going to face them forward. Hopefully with some trimming of the front plate and possibly v bands on the ends it should all fit together nicely.......
Image[/URL][/img]
Image[/URL][/img]
JJMclure
Post by JJMclure »
2 years since an update?!?!!?!!
ok so I got some axles
Image[/URL][/img]
JJMclure
Post by JJMclure »
fuel rails and bigger injectors
Image[/URL][/img]
I got an LS9 cam off ebay
Image[/URL][/img]
JJMclure
Post by JJMclure »
also got a third member
Image[/URL][/img]
then stuffed that and the axles into the housing by torchlight as the rain had got into the f@(k£ing garage electrics again
Image[/URL][/img]
JJMclure
Post by JJMclure »
finally managed to get a gearbox (long story)
Image[/URL][/img]
waiting for a rebuild kit for that to come over
also fitted some uprated valvesprings
Image[/URL][/img]
Am currently speaking to a guy about getting the engine mounted......hmmm I've been here before! SO hopefully there will be some real progress this year!!
Progress is progress mate :)
Stick at it. Are the shafts 31 spline?
There are some nice bits there to look at ;)
Well done JJ.
Pel
JJMclure
Post by JJMclure »
mgbv8 wrote:Progress is progress mate :)
Well done JJ.
Pel
35 i think......
35 spline = sooper dooper strong :)
JJMclure
Post by JJMclure »
mgbv8 wrote:35 spline = sooper dooper strong :)
Yep and more expensive! Dayum!
