Merlin Heads
minorv8
Post by minorv8 »
Mark, how distinctive lopey idle does it have with that cam ?
Pickup is mostly done, only some panel fitting left. Welding mostly done but it is back on its wheels. It would be so fun to fit a RV8 on the bed :D
mgbloke
Post by mgbloke »
The Idle with the mechanical 238 is surprisingly good.
DaviesDJ
Post by DaviesDJ »
I am checking twice daily for those Dyno results!!:-) any news??
mgbloke
Post by mgbloke »
Its going to the rolling road, Circuit Motors on Tuesday 3rd Sept for mapping. Should have dyno sheet then barring problems.
I think some mapping has been done on the road.
I am really pleased with my port matching but we will see.
last time on these rollers it made 326bhp, in theory it should make slightly more but the pickup and throttle response should be much better.
The most important thing is how it drives on track.
Mark
mgbloke
Post by mgbloke »
This is what it looks like except the bonnet bulge has now been extended forwards by about 80mm to clear the filters.
Anyone know if the Merlin heads are still available?
DaviesDJ
Post by DaviesDJ »
best of luck today:-)
mgbloke
Post by mgbloke »
I will try and get some vid of it on the rollers.
For some reason I always get very nervous when its on the rolling road, the noise and heat generated is quite alarming.
Not expecting big gains in BHP.
RR at 10.30
DaviesDJ
Post by DaviesDJ »
I think I would be the same - we all nurse our cars a bit, and all know when it is safe to give it the beans
minorv8
Post by minorv8 »
Yes, it is a bit nerve racking to watch a RR session but to be honest, I don´t feel any pity when driving the car. And besides, like one operator once said: you take your chances :D
Mostl likely it would have broken down already, the odds of the car breaking down on a dyno is quite small... I think :lol:
mgbloke
Post by mgbloke »
Well it is making a lot more power because now the clutch cant cope.
It slips for a moment at about 3500rpm then catches up again.
The rolling road operator said that the figures will be un reliable.
RR saying 372bhp so it must be reading high because that is not possible.
322 at the wheels. Only did one run so no time to optimise ignition.
Now I have to find a heavy duty clutch. Current one is 9.5 inch uprated.
Mark
DaviesDJ
Post by DaviesDJ »
Those sorts of figures may be possible I would have thought, the paddle clutch I have is quite good - a stage "3"
mgbloke
Post by mgbloke »
which clutch have you got and where from? Need to get something sorted ASAP
Blown v8
Post by Blown v8 »
I have a McCleod "paddle" clutch,Real Steel used to sell them
I'm putting over 400lb of torque through mine,with no slippage at all :D
DaviesDJ
Post by DaviesDJ »
Panther paddle item, LK performance sell them, but sen them your old friction plate to make sure they match it, 360 quid Ish for 3 part kit, I am running a 5 litre (not as high end as yours) with 100 shot of nos in a 4wd Landy with no slippage
mgbloke
Post by mgbloke »
Thanks guys I have ordered an AP racing clutch from V8 tuner.
I have now driven the car on the road a couple of times and wow what a difference. Much smoother stronger power delivery from low down. The camshaft has also been tamed with a very stable idle.
And the noise coming from those throttle bodies! 3rd gear acceleration is just vicious. Clutch is OK on the road. Should be fitting new clutch next week then back to the rolling road.
Definitely the right decision to port the heads and remove that filled in corner and fin.
Mark
