The front is 70mm + curve and the middle sections are 85mm + curve.
Which is lower than the standard item I believe.
The circle you can see on the front is 75mm in diameter.
As you can see I can only make maximum of 10mm shorter. I might do this but I do want the thottle intake to cause too much air turblulance around the trumpets themselves, the reason for marking where the inake would be and the reason why it is so close to the top of the plenum, I shall make some calculations to see if I can reduce the height, like I said ideally the front height would be 57mm.
ihatesissycars wrote:Is that not too tall?
