Exhaust Dilema
Hi Tom
I think Ians suggestion sounds pretty good, all the real steel ones are some sort of off set or spirel baffel set up, so will have no advantage over the vauxhall one, I would go with whatever is cheeper (and will fit).
topcatcustom
Post by topcatcustom »
Fancy that! Vauxhall Cavalier mufflers being the supercars choice :lol: Ian I dont suppose you know the size of the inlet?
TC
TC
Sorry but I don't
JP.
Post by JP. »
Running mine on the standard cast iron SD1 manifolds (4-2-1).
Cause can't fit tubular ones cause they are made for rhd and my steering collumn is on the other side.
According to the book Tuning Rover V8 Engines ( David Hardcastle) they ( the SD1's) perform well and more than some so called performance tubular/extractor designs. ( picture on page 30, upper pic and quote on page 28 )
I run them cause they where cheap, are small as I havent much room and still have no horsepower issues that I know of.
Offcourse there may be some horsepower improvement for me by choosing the right model of headers & design but at the moment I have more than plenty horsepower so I don't miss what I don't know....
:D :D :D
'73 Ford F250, 6.7ltr V8
Building a GT40 mk2
topcatcustom
JP I have ported my heads maybe a bit too much and the ports are slightly larger than standard now so cast manifolds will not go on without being opened up themselves.
One of my steel suppliers has got back to me and can supply the tube I want, not cheap but goes through the books so no VAT, I am getting 1 5/8" for modifying the primaries I already have (6m length might be a bit overkill!!!), 2" for the secondaries and more 2 1/2" for the remainder.
Before I order- thickness wise am I best going for 1.2mm for the 1 5/8" and 2" and 1.5mm for the 2 1/2"? Actually its a bit of a bugger as I only need about 2m of each, wouldn't normally care but the 2 1/2" stuff is nearly £50 a length, the 2 smaller sizes average about £24 each...
TC
the choice of wall thickness is really down to how many bends you have to put in it and how long you want it to last, if you can run 2 1/2 but if budget is limited then go 2" (you could always run 4 pipes as the other chap with one of these has.
topcatcustom
Yea I suppose 0.15mm extra wall thickness wont make too much difference! I'm definitely running 2 1/2" main, just wasn't sure if the pipe was about the right or at least the normal thickness!
TC
