spider plate ??
Perry,
Pleased to here you have sorted out the problem and the performance is coming back.
Are you running the cam with any retard, now you have improved the breathing and fuelling potential it would seem logical to try and push the power band up the rev range a bit so that you can achieve more top end power and a higher terminal speed,
You would appear to have more than enough torque to get you off the line quickly, if your timing gear is not adjustable Real Steel do offset keys for the cam that would allow you to retard the cam by 4 deg. and i think this would cure the running out of puff over 4000 RPM you mentioned a while back.
You may off course already thought of this but if not, worth getting a key for a few quid and slotting it in next time you have the front cover off.
Top secret details? come on, send me a PM I won't tell anyone.
PS whats your MPH per 1000RPM in top gearand what RPM is currently peak BHP?
Regards,
Regards,
Kev!
I cant remember mph per 1000rpm. If I get a mo over next weekend at the show I'll have a look. hp currently back up to 400 with 560 ft/lbs
I have got a 3 way cam sprocket, but its set to normal. Whats your thinking about setting it retarded??
Perry
Perry
Perry,
Setting 4 deg. retarded will move the power band up the rev range and give you more top end power, as mentioned you seem to have more than enough torque to get you off the line but seem to remember you saying that the engine runs out of puff before you get to the line.
If you give me your tyre rolling radius I can work out the MPH/thousand RPM to see what the optimal power band would be for your terminal speed.
Diff is 3.07? and the TH400 is direct top gear I assume.
Another 500 RPM or so of additional power band may make all the difference.
CastleMGBV8 wrote:Perry,
Diff is 3.07:1
Th350 is 1:1 in top gear
Tyre diameter is 28" when not moving. I think its more like 29.5" at high speed
Pel
Perry,
Ok lets assume the tyre is 29", that would be 4630 RPM at 130MPH ie 28MPH per 1000 RPM retarding the cam for more top end power should enable a higher terminal speed, 5000 RPM would be 140MPH.
If you still have sufficient torque to maintain yout 60ft times then your 1/4 times should be quicker
Also retarding the cam should help with your exhaust scavenging which with your restrictive heads is what is holding the engine back.
Check what the alternative slots will give in terms of advance/retard 4 deg.is what your looking for.
The slots in my cog will do +/- 4 degree's Kev!
I'll adjust the cam timing after the retro show to see how she runs at USC event
Sounds like this might help eh Kev??
It will be interesting to find out in a month or so
Retarding by 4 degree's wont give me any valve fouling issues will it ?
Perry
Perry
Youve got me at it now you Bugger
I'm just running through the job in my head and I reckon I cxould have it all done and running in 4 hours??
Rad, alt, dissy and water pump out. Drop the front of the ARB (4 bolts), front cover off. Move the cogs and put it all back together !!
no!!
I'm not doing until after the Retro Show.. Too many alterations will get me confused again
no!!
What was the net result Paul??gelmonkey wrote:Perry
I have done this to my engine.
You have the time to do this before the show you know![]()
You know you want too.
Paul
The engine certainly does run out of puff. 0-100 in 7 seconds and then another 3.6 seconds to gain 27mph when it was on song last year??
I would love to do this before the show, but I've had so much down time with engine breakage due to nitrous rtelated issues that I dont want to bog myself down again. I always moan at folk for doing more than one change to an engine and then not knowing why its not working. But I went and did it myself at the start of this year due to crap advice from an "expert"!! And most of my season has gone now. I've got Retro + USC and 1 RWYB in Sept.
At this moment I have just one thing to re tune, and thats the carb fuelling. Then I can adjust the nitrous fuelling back down to 250hp and see if I get a good pass. I also only have 3 bottles of nitrous for this weekend so its gonna be tight. If I can use 2 bottles for dialing in on Saturday I'll only have 3 passes in an 11lb bottle unless I start winding the pressure up to the 950-1000psi mark when its half empty. If I use about 2lbs per run the bottle is half empty after run 3. This is when the bottle pressure drops off hard during a run so it goes rich halfway down the track
Hi Perry
Im afraid I cant give you any results with this from my point of veiw as the car has not been run in anger.
I did it purely for extra top end grunt as the V8 has so much down the bottom end.
Having more top end should help me to blast past my buddy Malc and the chap that I look after in Thatcham.
Sorry I can't be of more help with this ,just thought I'd give Kevin's little thought flames a bit of a fan
P
P
I just thought up a new idea to make my own nitrous injection system that will be safe and easy to use on any V8 that has a single plane manifold. Easily tuneable without the need to strip the top off to change jets. The system consists of parts that are available to anyone off the shelf in the UK as long as you can use a drill and tap. I have the backing of a pro racer (this guy runs 6 seconds) in the USA who has offered to take my idea and make it all work including flow testing for just the cost of the postage to ship my manifold to and fro. But I think I can do it here over the winter to make a simple system that can flow from 50hp to 700hp. Once the parts are fitted to the manifold you will be able to fit all the pipework to 2 pairs of solenoids and that is it??
You can then run a 50 shot upwards depending on how much petrol you can deliver to go with the nitrous. And you will get even distributiuon to all 8 cylinders.
I'll keep this under wraps until I have a final design. But the final design will be FOC to anyone on here who can use a drill and tap
Hi Perry
good idea, can I suggest, when you have the design sorted, you draw it out and write up a description of the design and the principles that are key to it's function with the detail in where your design differs from others, stick it in an envelope and post it to yourself. Doing so saves allot of problems that can ocour if your design is successful.
