Idling query
almost blocked fuel filter?
Or filter mesh before fuel pump
Post by CastleMGBV8 »
Pete,
Where are your Lamba sensors situated?
sidecar
Post by sidecar »
CastleMGBV8 wrote:Pete,
Hi Kevin,
Its on one of the headers about 18" from the head. My headers are home made jobbies. I would have liked the lambda sensor fitted at some point where it could sample the gas from all of the cylinders from one bank of the engine but as the headers only join up at each side pipe the blanking plug would have been in full view. (It would have ruined the good looks!)
Why do you ask? :D
Pete
Cobratone
Is a Spanner
Post by Cobratone »
sidecar wrote:The AFR's are:-
Tickover= 12-12.5:1 (Goes a bit rough if I lean it off anymore than this)
Cruise=13.5-14:1
Acceleration=12.5-13:1
WOT=11.5-12:1
Pete, just for comparison my AFR's are: -
Tickover = 14.2
Cruise = 15.5
Acceleration = 14.0
WOT = 13.0
Overrun = 15.8
you must be using loads of fuel while driving, any idea what your consumption is?
sidecar
Post by sidecar »
Cruise=13.5-14:1
WOT=11.5-12:1
Tickover = 14.2
Cruise = 15.5
Acceleration = 14.0
WOT = 13.0
Overrun = 15.8
I know what's coming next....NO I'M NOT GOING TO FIT EFI. (yer GIT! :P )
I don't know what my MPG is, I find it totally impossible to drive my cob in a sensible manner for more than 5 minutes! :D
It must be between 5 - 40 MPG, does that help? :lol:
See ya soon.
Pete
Hi Kevin,
Why do you ask? :D
Pete
Just curious as I have read that you can get different readings depending on where the Lamba is installed.
If you have the usual cobra type system with long primaries exiting the front wing into a collector. then your a bit stuck as to getting readings from all four cylinders on one bank and are only sampling one of eight cylinders.
sidecar
Post by sidecar »
Hi Kevin,
Why do you ask? :D
Pete
Your not wrong there Kevin. At the end of the day it's better than guessing and its not as if I can adjust the mixture on a cylinder by cylinder basis anyway. (Well not without fuel dams and fuel lots, but that's NASCAR stuff really!)
I've had another mad cap idea, my motor obviously wants "more carb" at low-ish RPM but does not create enough vacuum to open the flap plate above the secondaries. Using the spare plate that I've got I'm going to drill a big hole in each of the two counter weights. I'll then fill them with solder and drill a small hole in each so that they are back to there orginial weight. I can then keep drilling the hole bigger until the flappy plate opens too soon. I just then need to re-fill the holes with solder and go back on drill size!
Its bound to work great. (or not!) :lol:
Pete
Pete,
With carbs the old fashioned method of reading the plugs is probably as good as any.
Just get the engine to run smoothly at idle and cruise on the lowest settings you can. Then do full power runs (WOT) and shut down the engine whilst under WOT and then read the plugs.
This will tell you not only if the mixture is correct it will show if you have correct heat range for the plugs but start the test with a clean set of plugs to give accurate indications.
You probably knew all that.
Cobratones figure show the benefit of EFI and throttle bodies with a programmable ECU as they are just about ideal.
sidecar
Post by sidecar »
Don't say that, EFI versus carbs is a long on going "discussion" on the Cobra forum, it will go straight to Tony's head!
At the end of the day EFI (or Gay-FI as its known on the Cob forum) will out perform a 4 block carb but I still like my carb, I like the fact that its a bit rough and ready. :wink:
Alex, I've sent you a PM.
John, I need an email address from you!
Pete
Richard P6
Post by Richard P6 »
sidecar wrote: At the end of the day EFI (or Gay-FI as its known on the Cob forum) will out perform a 4 block carb but I still like my carb, I like the fact that its a bit rough and ready. :wink:
My first experience of EFI was on old Montego Mayfair I bought a long long time ago. Up until then I used to fix my own cars but this thing was just far too complicated.
When it developed a fault, I took it back to the garage I had bought it from but they couldn't fix it. I took it to Gillingham Rover who charged me £90.00 to fix it but didn't. I took it to Lucas who spent three hours on it but couldn't fix it.
EFI I discovered, stands for 'Extra Flipping Intricate' (Polite Version)
sidecar
Post by sidecar »
THANKYOU....here rests the case for carbs! :D (Bun fight about to start, again!)
JSF55
Post by JSF55 »
PM sent Pete, i'll update my info shortly, once i can make head or tail of what the LC1 is telling me :)
So thats where it went !
sidecar
Post by sidecar »
JSF55 wrote:PM sent Pete, i'll update my info shortly, once i can make head or tail of what the LC1 is telling me :)
Just got to nip out and get some gas for my blow torch, when I get back I'll send the XL spreadsheet.
I've reduced the refresh rate on my LC1, before the numbers flashed up so quickly that it was doing my head in!
Pete
JSF55
Post by JSF55 »
Thats something else i need to do :)
bigaldart
Post by bigaldart »
So glad we have MFI and Methanol on the dragster. Carbs were a nightmare LOL
