Posted: Sat May 23, 2009 3:46 pm
No instructions? if not try down loadat
http://www.loco4fomoco.com/MalloryAdvanceCurveKit.pdf
Welcome to the well-known V8 Owners Forum, no matter what you drive if its V8 Powered you'll be made very welcome.
https://v8forum.co.uk/forum/
Personally I'd run a bit more than 10 degrees static, as you wind on more advance with the engine ticking over you will hear the revs pick up, this must indicate that it 'wants' more ignition advance. You do have to be careful though, if you just used this method to find the ideal static timing is would end up at round 18-20 degrees. This is because the cylinder pressure is very low due the the carb being shut. It sends the VE down the pan. If you did run say 20 degrees when you floored the throttle the VE would go up and the timing figure would be too high. I'd go for 12-14 but you will than have to tweak the dizzy so that it only gives 22-20 mech advance, thus giving you the 34 all in at 2700-3000 RPMCastleMGBV8 wrote:Rich,
You don't really wan't more than 34 degrees of total so 10 Static + 24 mechanical = 34 deg which is what a 3.9 should run best at.
If you look at the graph you will have 16-17 deg by 1500 RPM with the static set at 10deg.
Why? Vac advance has no effect at WOT (ie. racing), so why disconnect it?CastleMGBV8 wrote: You can set the static advance to 8-10 degrees and run the engine without vacuum advance or set it to no more than 5 deg and disconnect when racing.
jefferybond wrote:Why? Vac advance has no effect at WOT (ie. racing), so why disconnect it?CastleMGBV8 wrote: You can set the static advance to 8-10 degrees and run the engine without vacuum advance or set it to no more than 5 deg and disconnect when racing.
I'm amazed at all the comments on this topic to forget about the vac advance. Without it, light throttle response and economy both suffer! To be fair, it will have no benefit when racing, but no downsides either.
I limit my 3.5 to 34BTDC at 3500rpm (WOT), but my vac advance can go to about 48BTDC at light throttle (using megasquirt-n-spark extra).
Jeff
Well I am running an edelbrock 500 carb with vac advance and it's fine. I know I'm running mapped ignition now, but originally I was using the original opus 35DE8 dissy with vac advance and it really was fine.sidecar wrote: You may well be amazed about the comments on using no vac but the fact of the matter is that it does not work with and Eddy 500 carb!
Well to be precise it does not work with the 500 carb unless you restrict the static advance to a really low figure which sort of defeats the whole object somewhat.
Yes, running a 'decent' amount of static will be hard with a crappy mechanical distributor, but that's a shortcoming of the distributor, not a problem with the eddy 500 carb surely?sidecar wrote:
Running 48 degrees total advance may well be great but with the 500 carb (and possibly even with the SU's) the vac advance still adds too much extra timing on top of the static even when the throttle is opened and the vac in the manifold is reduced. If you are running a decent amount of static then the engine will kick back.
I bet when you were running the lucas dizzy with vac and the eddy 500 carb you were not running much static advance and possibly stiff bob weight springs, that could be why the setup did not kick back.jefferybond wrote:Well I am running an edelbrock 500 carb with vac advance and it's fine. I know I'm running mapped ignition now, but originally I was using the original opus 35DE8 dissy with vac advance and it really was fine.sidecar wrote: You may well be amazed about the comments on using no vac but the fact of the matter is that it does not work with and Eddy 500 carb!
Obviously the megasquirt improved things by allowing me to run more advance at idle, but still keep to 34BTDC at WOT, but it ran pretty good before that.
Actually, one thing you can do is keep the static timing pretty low (eg 6 BTDC), but use the NON-TIMED vac port on the carb (against everyone elses advice!). This will give a good advance at idle, but the low static setting will keep the max advance in check.
One reason they don't leave the factory like this is because it reduces the exhaust temperature, and means you might get more unburned HC out the back! Reducing the manifold temperature is probably a good thing for most of us.
Jeff
