Do I really need a lightened flywheel?
- topcatcustom
- topcatcustom
Rover flywheels are getting old, cast iron gets more brittle with age, add this the stress of machining it and you are removing material reducing its strength aswell and you are going to be accelerating it faster and you have a potential explosion on your hands.
PS I wonder how many government allarms I have just set off with that E word
- topcatcustom
- topcatcustom
Could one like this be adapted?
http://cgi.ebay.co.uk/CHEVY-V8-FLYWHEEL ... dZViewItem
Still lookin!
Still lookin!
How do multiplate clutches work? I've heard of them being attached to auto flex plates, which are just a sheet of thin steel sheet.
I presume the pressure/friction surface normally part of the flywheel is instead made as part of the clutch housing?
the auto flex plate holding the starter ring gear seems a lot lighter than a flywheel, so would using a twin disc or multiplate clutch mean the heavy flywheel can be discarded for a lighter flexplate? or do they need special flywheels?
- topcatcustom
I didnt buy the lightened ones as decided against going for an old flywheel that has been skimmed due to the possibility of it breaking up and loosing my feet!!! Plus they are not an awful lot lighter than standard so waiting for an ally one to pop up!
I have got myself an AP twin plate clutch
, but I dont fancy bolting it to a flex plate as I just cant see them running true without a bloody great torque converter bolted to it!
- topcatcustom
