Roller Rockers
winkle
Post by winkle »
Mark, those real steel pushrods are time consuming to assemble apparently and you need a lathe to turn them to length, and a drift to push the tips in if you are doing it yourself. (Thats what they told me).
They sent me a set of their HD pushrods last week and when I checked them the ends were welded on the piss which made them, well..... bent basically! RS didnt manufacture them, but...I wasnt happy.
Decided to give up and ordered a custom made set from Crane. Spoke to a gerrrl named Barbie! :lol:
Steve
Live dangerously, syphon fuel, smoke in bed, run with scissors
HairbearTE
Post by HairbearTE »
Check out the Manton pushrods website for amazing custom pushrods! pricey though.
Robrover
Post by Robrover »
The set of YTs I have have a small hole in the top of each rocker that lets oil escape and run down the top of the rocker. YT recommend fitting a small restrictor in the oil supply hole coming up from the head to prevent flooding the rocker covers with oil.
Because they are adjustable setting lifter pre-load is easy. Also seen them used on a P76 which oiled via hollow pushrods.
Post by ian.stewart »
Ive got a set of Kenne Bells, Full Needle rollers, came in a bucket of spares I bought last year, although KB do not carry Buick parts any more, TA Performance have the rights to make them.
sidecar
Post by sidecar »
winkle wrote: They sent me a set of their HD pushrods last week and when I checked them the ends were welded on the piss which made them, well..... bent basically! RS didnt manufacture them, but...I wasnt happy.
Steve
That's got me worried!
Were they the 5/16th adjustable ones that they sell fore RV8's and SBC, you have to knock in the required "ball" depending on what motor your fitting them to?
Regards,
Pete
winkle
Post by winkle »
No Pete they were different to the ones you are talking about.
Standard length non adjustable with the tip welded in, instead of pushed in.
Steve
sidecar
Post by sidecar »
winkle wrote:No Pete they were different to the ones you are talking about.
Steve
Cheers for letting me know!
mgbloke
Post by mgbloke »
The Yella Terra's turned up today!
After inspecting the adjusters, I dont need hollow pushrods as they oil through the rockers.
Cost $550 plus £61 import duty and VAT About £341
Very good service less than 2 weeks.
Now I need to start re building.
Mark
chodjinn
Post by chodjinn »
That's excellent, £80 cheaper than V8 Tuner do them for.
So what pushrods will you be using with them?
thanks
mgbloke
Post by mgbloke »
Im gonna try the standard pushrods.
The cup in the mechanical lifters seems slightly lower than the hydraulic ones so Im going to check the roller contact patch in the valve stem.
I think the only way to alter the geometry is to either raise or lower the pedestals.
Mark
chodjinn wrote:That's excellent, £80 cheaper than V8 Tuner do them for.
thanks
is that with our discount mate?
chodjinn
Post by chodjinn »
No! I only thought we got a discount with V8D? What's the discount at V8 Tuner then??
Doesnt anybody ever read things :lol: http://www.v-8.org.uk/forum/viewforum.php?f=4 :wink:
katanaman wrote:Doesnt anybody ever read things :lol: http://www.v-8.org.uk/forum/viewforum.php?f=4 :wink:
:lol: :lol: :lol: :lol: :lol:
kokkolanpoika
Post by kokkolanpoika »
chodjinn wrote:No! I only thought we got a discount with V8D? What's the discount at V8 Tuner then??
I order some parts couple of weeks ago at V8 tuner.. He says that only discount is for Crower cams only.. :shock:
Timo
