Injector Calcs.
once paypal sorts its self out and excepts my payment i'll order the bosch green 42lb ones from fiveomotorsport :evil:
They are now ordered :racing
just hope they are the right ones now :lol: :lol: :lol:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 0003703098
yup ;)
cheers stevie,
mmmm whats next to do now :lol:
done the pump, now the injectors, changed ecu, anything else? :lol: :lol: :lol:
Chevy LSx? :lol:
katanaman wrote:Chevy LSx? :lol:
ooooooooooooo marki i wish mate :lol:
fuel lines, map sensor, boost pipes, turbo...ummmmmm gearbox, clutch lol
stevieturbo wrote:fuel lines, map sensor, boost pipes, turbo...ummmmmm gearbox, clutch lol
:lol: :lol: :lol: :lol: @stevie
BUT forced is my next route, 8)
just to make sure i got this right,
my req fuel will be this yeah?
I injector flowrate (cc/min) ( 440 )
D engine displacement (cc) ( 3947 )
N number of injectors (piece, eg. 4 for a 4 cyl port injection) ( 8 )
Simplified equation is: req_fuel = 6.49 * D / N / I
so 6.49*3947/8/440 =7.277 (7.3)
i have got that right aint i :oops:
Where have you got the equation from ?
using the online stuff on RCeng's site is easier. Takes less thinking :)
r2d2hp
Post by r2d2hp »
Using the RCEng guide based on 300bhp it works out that you need 23Ib injectors. I assume this is based on the injectors being able to meet all the demands on the engine supplying max power continuously
I also read that running injector that are too large can effect tick over and slow running, is that correct.
stevieturbo wrote:Where have you got the equation from ?
here mate:
http://www.vems-group.org/wiki/index.ph ... torOpening
But what is the equation trying to do ?
Whats it trying to prove ? Is it something specific to the needs of the VEMS ? or a general equation ?
Dont forget, that equation ...
Assume
* fuel density=0.755 g/cc
* AFR=14.7 at stoich
* intake air density = 0.0012 g/cc (at MAP=100 kPa, which might be a cheat from the real 101..104kPa ?)
* (alternate+1)*divider = N (see N below)
It isnt calculating a general injector sizing question.
dnb
Post by dnb »
It's just to set the base pulsewidth for the ECU. Probably best to use the equation as-is ;)
BTW Tony - are you going to wire the injectors in batches of 2 now they're bigger (instead of the batches of 4)
not sure Dave,
what would you recomend?
does it need to be done that way now then???????
and is there a diagram of it mate???
