Rover V8 pulley alignment
LandyV8
Post by LandyV8 »
mgbv8 wrote:I recently broke my thrower ring. I did get a replacement but that was after I had rebuilt. I cant see any problem with the pulleys on mine. I got the ring from one of the guys on here via the wanted section.
Pel
So does that mean if you had added the oil slasher it would have put your pulleys out by at least 1.5mm. Did you say you are using P6 pulley and P6 pump?
harvey
Post by harvey »
The oil thrower is 1mm thick.
crayefish
Post by crayefish »
I may be wrong, but I don't think a mm is anything to worry about with pulley alignment. My alternator was shimmed with washers just by eye!
Zander
topcatcustom
Post by topcatcustom »
I thought this was a big problem where it was out by a whole belt thickness or something! I reckon a belt could run 5mm out on a RV8 without any damage!! (I'm not saying it should of course!) Shimming by eye is what I have done in the past as well.
TC
DEVONMAN
Post by DEVONMAN »
LandyV8,
I may have missed this in the text somewhere but how much misalignment have you actually got.
DEVONMAN wrote:LandyV8,
Sounds like 1.5mm ish ?
If he has a rubber front seal I wouldnt bother pulling it all apart to fit a thrower ring!
Pel
No! I'm saying that not having the oil thrower ring hasnt made a difference worth worrying about. I've fitted the rubber conversion seal to my pre SD1 cover and its not leaking. I use the original MGB V8 pre SD1 front cover and pump. If I put my laser aligner on the pulleys it would show the error I guess. But as its so small I havent bothered.
harvey
Post by harvey »
mgbv8 wrote: If he has a rubber front seal I wouldnt bother pulling it all apart to fit a thrower ring!
Especially as the thrower isn't fitted with the lipseal.
DEVONMAN
Post by DEVONMAN »
The later covers (Rubber seal type) have an eyebrow inside over the seal which would foul on the oil thrower
Regards Denis
YEP !!
LandyV8
Post by LandyV8 »
topcatcustom wrote:I thought this was a big problem where it was out by a whole belt thickness or something! I reckon a belt could run 5mm out on a RV8 without any damage!! (I'm not saying it should of course!) Shimming by eye is what I have done in the past as well.
Well if you look at this picture http://s144.photobucket.com/user/markwi ... ies2a%20V8 It looks pretty near to 5mm. I'm obviously being over fussy, but it seems a shame to do a rebuild and not get everything spot on. Surely Rover wouldn't have had the belts out of alignment?, but then again it is Rover
Is the water pump pulley on the right way round ???
5mm is unacceptable mate ...
DEVONMAN
Post by DEVONMAN »
mgbv8 wrote:Is the water pump pulley on the right way round ???
It dosen't look like it is as the pulley almost touches the water pump inlet neck on my son's engine. There seems to be a larger gap in the photo.
Having said that, LandyV8 did say he had also tried a buick pump and had the same misalignment.
Denis
Denis
Same here Denis!!
My pulley almost touches the inlet. And Landy's does not ?? Worth a try eh ??
LandyV8
Post by LandyV8 »
Denis
Same here Denis!!
The buick pulley is a one piece, can only go on one way. It has the same dimensions and clearances as the P6 pump but more room between radiator and pump nose. See here http://i144.photobucket.com/albums/r190 ... hs4111.jpg
