Hi Shaun.
Yes it will require the gearbox out - a lot of work I know but if needs must .......
Unless you know for certain the state of the clutch plate I would check that too while in the same area.
regards, mike
Clutch noise ????
PershoreTVR
release bearing
Thank you Mike. I'm not very hands on so work will need to be done by my garage. I think that will involve having the gearbox out? Is that the case please? I'm hoping I can defer the work until the winter (though I drive my TVR all year).
Shaun
Shaun
PershoreTVR
gear noise
Turned out to be a loose bracket! Feeling mightily relieved, if not a bit daft for not checking the simple stuff first. 2 New bolts and all is fixed.
Thank you for the advice Mike.
Shaun
Shaun
