Rover v8 Camshafts again
Gav, your crower cam did it need valve cut outs in the pistons?
pits what was the price of the stealth?
- ihatesissycars
My 232 didn't no. To be honest though i didn't check as Allan said it wouldn't.
Nothings hit yet though so must be ok!
It has a wicked kick to it at 3k, enough to get the wheels spinning in second when it goes for it so the higher up cams must be even more mental!
- ihatesissycars
so your not using pocketed pistons then Gav,
imay take a gamble and order this cam and check every thing when it gets here,
was gona get the 234 but thats a bit too mental i think.
what lifters you running Gav?
- ihatesissycars
cheers gav,
looks like im going for the crower 50232 and some more crane hi- rev lifters then
thought i had the 50232 specs but can't find them
i have the 50233 and 50234 specs below:
http://www.v8forum.co.uk/50232.htm <edited>
http://www.v8forum.co.uk/50233.htm
http://www.v8forum.co.uk/50234.htm
Gav have you your cam spec sheet still???
as want some ones advice to see if its a step better than the piper 285.
just added the 232 specs
- HairbearTE
- Guru
- ihatesissycars
50232
Grind lobe centre - 276HDP 112 degrees
Advertised intake - 276 degrees
Advertised exhaust - 281 degrees
Duration @ .050" - Intake - 214 degrees
Exhaust - 218 degrees
Gross lift 1.6/1.6 - Intake - .488"
Exhaust - .490"
High Performance CompU Pro - Performance Level 3
These camsoffer extended rpm range with emphasis on upper bottom and top end power.
RPM Power Range - 1800 to 4500
Redline - 6000+
http://www.crower.com/misc/m_cat.shtml
Exhaust - .490"
Redline - 6000+
you were beaten gav
now need the piper 285 spec sheet and we can compare,
mines the old type 285 as i think they changed the cam slightly.
- ihatesissycars
Myself and Neil at Caprisport are going to possibly build a high comp 4.6,
but going to do that over period of this year and the winter,
so we are going to freshen up Neils old 3.9 track day engine (that i own now and used for past 3 yrs) for now for some fun,
we have some stg2 heads, just need to sort a cam now thus why not wanting the pocket piston prob, as want to spend most my money on doing a new engine now,
- ihatesissycars
