Dave,DaveEFI wrote:What discs did you use? Presumably vented if for Cosworth callipers?chodjinn wrote:SD1 axels are pretty easy to convert to discs from drums, I'm running a pair of Sierra Cosworth calipers on the rear with built in cable handbrake - they are available off most sierras/granadas.
I would not recommend you plan to start with a RV8 then Chevy, stick to one and go with it, for ease and expense reasons if nothing else!
I believe they are Mercedes discs that were ever so slightly redrilled to suit.
And they are solid discs, only 4x4 cossys had vented rear discs.
