The mx5 Rv8,.. thing!
stagcar
Post by stagcar »
just had a look at the vids mate
Very smart looks like the rear wheels are on fire in the end :D
Hope its just the gasket blown fingers crossed for you mate
Derek
Rust rust and more rust
topcatcustom
Post by topcatcustom »
yeah the brakes could do with being a bit bigger :lol:
Well Fast Car mag came out for a photoshoot yesterday which took 4 hours and the pics look awesome, got to be processed yet so will be even better when done, best thing is that the car used no water, temp was ok, and no excess pressure in system so I guess the water incident last week must have been an air lock or something?? Time for some new rear tyres too now tho :roll:
TC
gelmonkey
Sergeant Monkey Face
Post by gelmonkey »
Hi Tom
Let us know when the car is featured and will get a copy of the mag.
Had my car featured in 1993, same mag, and was in print very quickly after photoshoot.
Well done again mate,your car is awesome.
P
PS Where those valve seals of any use?
topcatcustom
Ah sorry I dont believe I thanked you for them! The only problem I can see with them is they are fairly thick on the valve seal part- so the guides may need to be reduced to stop the spring retainers crushing them when at full lift. I already skimmed the guides so need to whip a rocker cover off to see how much clearance there is!
TC
gelmonkey
Post by gelmonkey »
Hi Tom
Glad to hear you got them.
They are a little thick at the top but I have used them several times on different RV8s and not had a problem.
With your set up though it maybe different!
P
topcatcustom
Hopefully they will go on ok- my cam has .5" lift though which may be pushing it a bit.
TC
topcatcustom
Hmmm- managed to catch a glimpse of my boost gauge for the first time today (not exactly easy to take your eyes off the road under WOT in that thing!!)- looked like 12psi in the split second I saw it :shock: No wonder it's making silly power and struggling to keep cool!!!
Although even when accelerating hard I still only need to use half throttle which is about 6-7psi so shouldn't be too much of an issue- cant explain how insanely FANTASTIC it is having a light car that will kill almost any other cars on the road by just moving your right foot down about 1" 8) :D
TC
gelmonkey
Post by gelmonkey »
Admit it you are just reliving your childhood.
My cars faster than your car :lol: :lol:
Just watch out for the Dibbles Tom they would love to take the smile off your face.
P
gelmonkey wrote:Admit it you are just reliving your childhood.
P
Reliving his childhood??
Have you met Tom?? He's only had his driving licence for 50 minutes :lol:
He's reliving his childhood before he has the time to remember it!
Good on ya Tom :)
Pel
gelmonkey
Post by gelmonkey »
:lol: :lol: :lol:
andyv8van
fuel regulator
Post by andyv8van »
topcatproduction wrote:Well things are actually going back together now! I made up a thick ally spacer and adapter to hold on the crank blower drive pulley which (after warming up) slid straight onto the front pulley and bolted up nice n tight!
Blower is also back together now, I rebuilt it completely and made the drive receiver which is the top hat thing bolted onto the RH cog, made and polished the ally blanking plate on the rear and have done a small one for the front, and started on the billet ally drive snout!
Stainless cap head bolts all round, timing set is on and front cover back on permanently.
Once I torque up the heads and sort the lifter pre-load with the shim kit I have coming I will bolt the inlet manifold on, and the blower :D Then just have to finish the snout, jet the carb a bit richer for a starting point, then try the engine for size in the car :shock: and probably modify the sump and maybe the headers a bit...
shiny bits- couldn't resist!
hi Tom,
What pressure unit are you using, looks like the sort of thing im looking for to fuel my charger install
love the car, big engine little car, my sot of thing .lol
Andy
3.9 V8 Mini Van....THE BEAST
topcatcustom
Holley fuel pressure regulator- don't get one! Pressure is up and down like a yoyo depending on temperature etc, I was going to rip the internals out and just leave it as a plain T piece, and fit a syntec or filter king pressure regulator in line, I can only suggest you do similar!
TC
gelmonkey
Post by gelmonkey »
Andy
I would be careful of the Filter King unit as well.
I have two fitted to my car and one of those is not as good as it could be!
Tom
Do you have a date for your mag debut?
Paul
andyv8van
Post by andyv8van »
Thanks guys
will take that on board
was looking at fuel lab type pressure units
Andy
topcatcustom
P, no date yet- think this coming issue is a euro special so won't be in there, hopefully the one after!
TC
