Was a Paxton supercharger conversion, now a Rotrex C38-91
Oil Cooler arrived today,
had to mod the brackets a bit as it was touching the intercooler,
will see if it clears with the new brackets tomorrow night.
well had a result tonight,
by modding the oil cooler brackets it now just clears the intercooler, :D
view of the intercooler through the capri lowwer valence cut outs,
One of the mounting brackets, needs tidying up, edges and corners rounding off.
And at last intercooler bolted in and in place using its own mounting points,
next job is to cut away part of the valence crossmember box secion to clear the rad and fans, 8)
well as i got sent home from work due to the weather, i thought ideal time to go out in the garage, WRONG,
Snow drifted up the door and i thought sod it,
New Rad is ordered though :lol:
Well had a better day today,
managed to bend and cut the bonnet brackets around and bend the catch mech and now the catch works and clears the intercooler,
Coils packs have arrived, (Thanks Rossco) Image
the cross member is cut out to clear the fans, and have a rough idea on a cooling fan bracket, :D
After a 2hr drive this morning i finally got to meet David from SC Power,
and picked up these goodies :D
after a lengthy chat and cups of coffee, it was time for the 2hr drive home,
Cheers for meeting me so early this morning mate,
another box to unpack, but this is nuts and bolts idlers etc,
Now that's progress !
itching to get it all fitted, but waiting on the poly vee belt,
should be here wednesday :D
Time for a large JD'n'coke and get my reading head on
daxtojeiro
Forum Sponsor
Forum Sponsor
Post by daxtojeiro »
Have you got much much bigger injectors yet?
Is your fuel pump a powerful aftermarket device?
Are your fuel feeds up to it?
Do you have a lot of petrol stations on the way to work :twisted: :twisted:
thanks
Phil
440cc green bosch motorsport injectors,
044 bosch motorsport pump,
3/8 main fuel line (-6) and 6mm return pipe,
yup plenty of fuel stops to work :lol:
also spark plugs?
running NGK 6's at present, 7? 8? 9's?
7's would be plenty cold.
Not honestly sure why standard TVR's etc run 8's though. That seems ludicrously cold.
run a slightly recesed electrode like we do on nitrous?
the recessed electrode is pretty much dictated by the heat range.
r2d2hp
Post by r2d2hp »
HiStevie They dont run an 8. They use B7ECS
http://www.sparkplugs.co.uk/pages/datab ... rtno=B7ECS
Speaking to NGK recently these are considered to be racing plugs
Return to “Forced Induction”
