BMW 4.4ltr V8 into E36 Saloon..!
BMWE36V8
Post by BMWE36V8 »
Your oil pump looks interesting, are you going to test the engine before you fit it to see if it makes oil pressure..??
My diff ratio is 2.65:1, which match to my gearbox (1:1 fifth gear) means it should do about 170mph at around 6200rpm and it doesn't take to long to get to 150 so I quite sure it would do it...
beelzebubs
Post by beelzebubs »
Now i have a spare 4.4, I'm going to take the pump out of that, spin it up on the lathe and see what pressure it makes, then do the same on the hdi pump, hopeing its somewhere close.....as I'm useing the escort on the track, I'm looking for power rather than top end
can never have too many spae v8's :)
beelzebubs
And 740 loom thinned out headlights to taillights keeping the abs and asc
beelzebubs wrote:And 740 loom thinned out headlights to taillights keeping the abs and asc
What a mess! :shock:
beelzebubs
It actually lays out quite nicely.....certainly no more than maybe a standard e36 loom, i reckon if someone was considering a v8 the loom transplant would be the cheapest way to go, even the ignition barrel with the ews fits the e36 column.
the dash is even the same size and shape so would fit the 36 dash top, the heater plug is the same, as is the wiper motor and sunroof, i don't know about the stalks, but if that's the only cut and shut to do, its a lot cheaper than a stand alone ecu
beelzebubs
Yeah
http://www.youtube.com/watch?v=xWJnl7sGkCM&sns=em[/code]
beelzebubs
When you were doing your exhaust, did you consider an m42/45 for the drivers side?
BMWE36V8
Post by BMWE36V8 »
M42 has the wrong cylinder pairing, so I just made my own, had a look at mine today, considering twin turbo's.... :twisted: :twisted:
BMWV8E36TiNZ
Post by BMWV8E36TiNZ »
Hi Steve,
I have been wanting to do the same conversion as you have but into a Ti down here in New Zealand, finding a 5 speed from a 530i hase been a bit of a problem as very few of the V8s here are manual, I may have to import one from the UK or US, do you have a contact for the people who do the clutch kit like you fitted to yours, also do you have any other pictures of how you did the engine mounts?
Cheers Paul
BMWE36V8
Post by BMWE36V8 »
Hi all,
Quick update, ran the Beemer at santa pod on sunday, a first for me and the car.... pleased with the times, didn't change tyre's or pressures in them, ran it exactly as I would drive her on the street and managed a 13.44 @ 105....
I will post some videos in the 1/4 mile section...
Steve.
dam13n1
Post by dam13n1 »
I build again in e46 v8 s62 steve I ask you whether you could extend me as an oil pump? what would the cost
The mega effort with n62 I do not share
last month I have a charger built into the 4.4 m62 in the e30
sorry for my english:(
zuletzt habe ich einen charger an einen 4.4 m62 eingebaut
Very tight!, a good job.
Iain
Post by Iain »
Finally i am getting closer..
Picked up a 2001 Full E39 540i with 6sp manual! :)
Let the head scratching commence!
BMWE36V8
Post by BMWE36V8 »
Hello,
Been a while, I've been a bit busy helping my mate, the 2005 Mustang drag car I helped my mate build ran a 9.04 @ 149mph last Sunday at Santa Pod, so very pleased with that...
Back to the Beemer, I'm running her at fighting torque on Sunday 9th Sept at Woodbridge airfield, I will let you know how I get on and post some vid's.. Fingers crossed she will perform well...
Steve.
choke
Post by choke »
Good luck! :racing
