Cheers for the info Perry.mgbv8 wrote:I have twin pumps. The one for the nitrous feeds 15psi via a 1/2" bore line to the engine bay. This connects to a twin outlet regulator that feeds both my fuel solenoids. This is a dead head setup at the moment. But I do know how to adjust it. This is less fiddly than feeding both systems from one pump.
sidecar wrote:Cheers for the info Perry.mgbv8 wrote:I have twin pumps. The one for the nitrous feeds 15psi via a 1/2" bore line to the engine bay. This connects to a twin outlet regulator that feeds both my fuel solenoids. This is a dead head setup at the moment. But I do know how to adjust it. This is less fiddly than feeding both systems from one pump.
I suspect that you setup is far more radical than the system that I'm going to fit
I'd appreiate you thoughts on the following setup bearing in mind that I'm only after 75 BHP for road use.
One Carter 72 GPH 8 PSI pump feeding a Holley bypass regulator set to 7 PSI with a return pipe to the tank (My carb is OK with 7 PSI at the moment).
The 7 PSI will feed the NOS system and the carb, I may or may not run a 7 PSI low pressure NOS cut off but I will run an RPM window switch.
I hope that I've not hijacked this thread.
JSF55 wrote:Mc gills on ebay just sent me a link to this, cheap ! but what do you reckon, better to go for something bigger ?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... EL:GB:1123
oh i have cash in my paypal account !
I looked at the other pumps they do, but noticed there all interupter type pumps, surely that would be worse?sidecar wrote:JSF55 wrote:Mc gills on ebay just sent me a link to this, cheap ! but what do you reckon, better to go for something bigger ?
That looks similar to the Facet 'Cube' pump. The PSI looks a bit low for the NOS system to me, I think that 7 PSI would be the minimum that you should go for. (But this is all new to me!).
32 GPH would be OK if you are using the pump for the NOS jets only.
Perry, cheers for the reply, your method of testing the low to the NOS fuel jets is a good one!
Hi big Ddbv8 wrote:A low pressure fuel supply is okk as long as its constant. You just need to establish the correct nitrous to fuel ratio you need for your set up.
I take my fuel from the injection supply which is regulated to 45psi.
Hence i run a ratio of about 2.5:1, ie a 250 nitrous jet and a 100 fuel gives me 125 bhp. The power is half the rating of the nitrous jet on a wizards of nos kit.
Perry, what ratio do you run with your lower pressure fuel supply?
mgbv8 wrote:The Blue pump will serve you well mate. Its what I use on the carb side. It used to be my nitrous pump until I fitted and Edelbrock pump on the gas side and retired my Carter pump a few months back
