Project no.2! **1971 Ford Maverick Grabber**
A quick hijack of your thread Tom if you don't mind.
John,keep the used disc's and use them for hand flatting in the final stages.
A 400grit disc after 10 mins use on a DA is roughly a 1200 grit afterwards.
Saves money and a double usage...... result.
Am off to count all the money I've saved now
Paul
Paul
- topcatcustom
Well spent a couple of hours over the weekend and got it 99% stripped out and on the spit, is a bit high so will chop 6" off the legs at some point but works perfectly
After a quick height adjustment I can easily roll it over myself 360degs, already I can see it making this bodywork sooooo easy, welding, sanding the lot!
Bit messy but this is almost everything that came out of the car- not much when you really think about it considering the heap is mainly the seats and suspension/drivetrain!
It's going in to be blasted as soon as I can get it on the trailer! Gonna get them to just do the fiddly bits and leave the big flat areas which I will do by hand to prevent the risk of any warping etc- cant wait even though I know it will look like a sieve when it comes back
TC
- topcatcustom
BBQ at Toms next summer
I recon by then you'll have finished the yellow peril and we could stick a complete ox on that rotisserie
Big log fire inderneath and a V8 to turn the spit
Now that sounds good
HI Tom
I was more thinking twisting it corner to corner and introducing perminent bend end to end when you start repairing panels that stiffen parts of the chassis/ body with it at an angle it isn't normally at. Remember it is a 30 somthing old body/ chassis, the steel will be no where near as strong as when it left the factory even if tin-worm hasn't got to it. A mini body used to take 2 to lift even without the subframes in and that is quite a bit bigger.
Sorry, but if it were me I would put it on a level surface (or at least 6 axel stands with the tops all at exactly the same height) pop the doors back in and put a few stiffening bars in it before you go any further.
- topcatcustom
as if i would,
he is a lucky one then,
