I also killed a rad using the cable-tie type thingies through the rad technique, this was also on a landrover but at the time it wasnt doing much if any offroading, mostly motorway work.
Avoid!
Probably ok as a temporary solution though. My new rad has the fan screwed to the frame that encases the cores.
Electric Cooling Fan Reversal...
- Pocket rocket
- topcatcustom
I did the cable tie thing, even made some rubber washers between the bits and put heatshrink over the ties first but was never happy with it!
So yesterday I took it out and welded a couple of small ally angle strips down it for proper fan mounting, only took about 10 mins but same old sh1t eh- doing a bad job twice or doing it properly once!!!
TC
