manifold enquiry
topcatcustom
Post by topcatcustom »
5 bar or 5 psi?! 5 bar is about 70psi!!!!
TC
try 5 bar :D
slots anywhere really, thats just a massive design weakness. Slots in the skirt, or equally important if not more, slots behind the oil control ring.
They will not last IMO.
Whilst not ideal, even if you can buy some off the shelf quality pistons, and skim the crown a little to help reduce CR. At least the actual piston design will be strong.
bones
Post by bones »
i was told 5 bar, but i think he had about as much of an idea on turbos as ive got, which says it all :oops: . so those pistons are no good then, so looks like pistons will be forged,just need to decide on what engine size??. what sought of comp should i be looking at with using a blow through carb. lower the better??
compression is very dependant on power goals, ignition setup, intercooling used etc.
Lower is most certainly not better.
I'd say for most cases, using mapped ignition with decent intercooling go no less than around 8.5:1.
Engine size is totally up to you.
Boosted LS1
Post by Boosted LS1 »
Slotted rover pistons crack at 10 psi so imo you could use them happily at up to 7 psi which is actually quite a big performance increase.
It doesn't pay to skimp on pistons if you plan further upgrades though.
bigaldart
Post by bigaldart »
I think that is 0.5 Bar if they are good for 5 bar no one would ever use forged. 0.5 bar is 6-7 psi. Depends on what the target is.
Alan
bones
Post by bones »
i guess we can all assume i got the 5 bar thing wrong :oops: . what would 7psi be in bhp in a 3.9 rover using intercooler and a 600dp carb (which was built to used with a procharger ), :? rich
kiwi303
Post by kiwi303 »
well, standard atmospheric pressure at sea level is 14.7 psi, so 7 psi is about +45% on N/A pressure, so figure the engines are a bit less efficient, and call it between 30% and 40% more power than unboosted. A lot will depend on your valve timing and ignition setups.
bones wrote:i guess we can all assume i got the 5 bar thing wrong :oops: . what would 7psi be in bhp in a 3.9 rover using intercooler and a 600dp carb (which was built to used with a procharger ), :? rich
600 DP is too big for blow through on a RV8. I could never get one to work right. I ended up with a 465 modified for a DP.
The 600 would only work when half the carb was used.
Use a smaller carb.
bones
Post by bones »
Ok then the easiest thing is for someone to explain the best way and a cheap way of getting 500bhp from a rover v8, using a blow through carb set up or carbs if su,s are ok and an intercooler. And please reply as if writing a book called ,turbo'ing for dummies. :) I thank you.
berty
Post by berty »
bones i have got a set of log manifold for the rv8 mate if you want to see picture i can post them up :lol:
Return to “Forced Induction”
