Couple of pictures I have nicked from Tom the Rolling Road guy's photo file
Andy, what did you put in your letter, save me buying the magDarkspeed wrote:My reply letter got printed in this months issue![]()
I think there is little hope of that, ever seen him in "kit car crisis" on Discovery Home and leasure? he surrounds himself with a load of mates that all view a "project" as a way to blag more goods and services out of some unsuspecting supplier who thinks they will free advertising/ air time and sinceerly believe the world owes them a living.topcatproduction wrote:Good one, maybe we should all write in to defend the RV8- then he would perhaps loose a little pompousness!!!
Wait till I see Will Hollman again, my little RV8 makes more power than his SBF, but down a little on torque, but my car, im guessing was set up on the same rollers, Dave Walkers?? so they should not be that far different, I wonder if he is brave enough to go to the CF show this weekend, If he was brave enough to put it on the strip, Boy, would I like to pick on him, especially as he had my Mexico arches for his Capri,Darkspeed wrote:Hi Tone
letter went something like
Defending the Rover V8
Even with its poor cylinder head design and without expensive modifications the Rover V8 does in fact hold its own quite well in the realm of the pushrod V8 - especially with respect to your own Ford 302 small block which with its modifications is comparable with the engine in my car, although the engine in mine does not benefit from a big valve head and produces what power it does through the restrictive standard Rover valve sizes.
Your engine at 5.0L and also benefiting from a bit of a tune up at the rolling road produced - 289BHP and 300ftlbs of torque through the assistance of big valve alloy heads, cam and throttle bodies. That's 57.8BHP/litre and 60ftlbs/litre. The figures from my 3.9 are 59.5BHP/litre and 65ftlbs/litre respectively and I am sure if the car had benefited from a bit of a tune up to optimise it these figures could have been improved a little and the the figures for my 3.9 are not exceptional and can be achieved quite economically. The standard Vitesse 3.5 figure is 54 BHP/litre, that's less than 7% down on your modified SBF figure. An RV8 of any standard capacity could make the specific outputs equivalent to your modified SBF quite easily. The RV8 was never destined to be a big capacity motor, there are other Buick designs out there for that task but as a small capacity V8 engine its as good as many litre for litre.
However what really makes the RV8 such an attractive proposition and so popular is not the engine as a lone entity but the easy availability of the LT77 5 speed manual gearbox and latterly the R380 which is where US engine installations get expensive and agricultural - the description of the gearchange in the article on your car made me smile as it is exactly the same as in my mates genuine Basil Green Perana, difficult at best, and what prevents good US iron installations being really popular and economical propositions. The US iron engines may produce good power once modified, but who wants a great engine mated to crappy gearchange or a slush box in a sports car.
The Rover V8 will never be able to compare to modern V8's or V8's that were developed with an eye to motorsport during an era where the manufacturers raced to out do each other for higher HP figures, its development stopped when Rover bought the design apart from what was absolutely necessary to keep it legal. It's a 50's design small capacity V8 and comparisons with it can just as easy highlight deficiencies in larger capacity engines as they can in making it appear underpowered.
Would I consider anything else? Not really, it sounds great weighs very little and back in the 60's it was given a makeover and won a F1 world championship
And printed as such
His response went along the lines of his car has such low power because of restrictive manifolds and 9.0:1 compression - and should see 350BHP with that sorted - and his gearbox is crap because he built it. So more defending the SBF than trying to slate the Rover so perhaps I made a point.
Andrew
