Oil cooler outlet/inlet (Rover V8)
ged
Post by ged »
I've got a new interim cover in the garage so I'll check the threads in the morning & let you know.
spend
Post by spend »
"M18 as I said at the beginning (for the interim covers), preferred solution is an M18-NPT adapter so you can either plug or use for temp/pressure senders." is a load of old tosh, so don't take any notice of it! - it is M20, but the use of NPT adapters is still valid ;)
All the serp TVRs (all interim) came as standard with the side one blocked and the bottom one with the pressure sender. I think I know of a couple of owners with blanking plugs left over after adding temp sender adapters if you get stuck. TBH its probably cheaper to get a suitable M18 plug from a local hydraulics place though.
ged
Post by ged »
I've just measured the threads on my interim front cover. M20 x 1.5.
DEVONMAN
Post by DEVONMAN »
Seems to be some confusion about the size of the oil cooler fitting on an interim cover. It may be that some are measuring the inside of the hole and others are measuring the outside of the bung/pipe fitting.
The thread should be based on the bung size which I believe is M20x1.5.
Regards Denis
ged
Post by ged »
No confusion for me mate. 35 years in precision engineering. :lol:
DEVONMAN
Post by DEVONMAN »
ged wrote:No confusion for me mate. 35 years in precision engineering. :lol:
Yeah. I agree with your sizing at M20x1.5
ged
Post by ged »
Thanks DEVONMAN, I hope you didn't misinterpret my reply. Sometimes what you write comes over all wrong. :)
spend
Post by spend »
Grovel! Grovel! Grovel!
It is definitely M20x1.5, ignore everything I said unless you are looking for the adapter to plug / sensor the stepper motor. I must pay more attention to crossing out and underlining (multiple choice was never my forte).
I shall humbly edit all the posts above just to make sure their is no confusion as a penance;)
ETA: In fairness I did answer the OP originally...
To: AdamR
Posted: Mon Mar 23, 2009 9:17 pm
Subject: Re: Oil cooler outlet/inlet (Rover V8)
Both oil cooler ports on the timing cover are M20 x 1.5 pitch definitely Wink
I stuck one of my stamped sample bolts in a cover I have off at the moment.
ged
Post by ged »
No worries mate, we all make mistakes. :)
topcatcustom
Post by topcatcustom »
Is the length crucial and normal hex head?
Blimey Ged, I vow to never question anything engineery you say- as you've been doing it for 10 years before I was born :lol:
TC
ged
Post by ged »
Hi Tom,
If you can wait until the morning I'll give you the dimensions of the plugs that are fitted in the cover & yeah I know I'm an old git.:lol:
Regards Ged.
ged
Post by ged »
As promised. The section of the O-Ring is 1.5mm & the thread has a 30 degree x 4mm chamfer. The text isn't very clear but the small diameter should read dia 11.8 x 5 long.
topcatcustom
That looks like a proper OE type jobbie- can I not just fit a couple of shortish blanks (bolt types) with dowty washers? Sorry Ged I'm probably making you cringe :lol:
TC
ged
Post by ged »
Hi Tom,
I don't see why not. The worse that will happen is it'll leak. :lol:
ged
Post by ged »
Tom here's a good selection for you.
http://www.airlink-compressors.co.uk/Fittings/plugs.htm
