Mallory Twin Point Electronic upgrade.
desertrover
Post by desertrover »
tetlow wrote:I am told the upgrade is very easy.
Replace points base with new base + pickup.
3 wires, +ve, ground and coil.
I was told you do not even have to redo the timing! :?:
Can I use it together with my Mallory Hyfire VI AL.
And is this reliable, because I take my Landy to Africa.
Or is it better to stick with the contacts and Mallory Hyfire Vi AL?
tetlow
Post by tetlow »
I would contact Real Steel. They seem to be on the ball with the latest info.
gd302
Post by gd302 »
it should trigger the mallory ok,check your wiring diagrams that came with the val
