nos fuel advice
General Chat About Nitrous Oxide.
What are the flow rates for the Red top pumps Topcat??
I use a Carter Marine pump for my Weber and a Holley Red top for the Nitrous.
Both are actually capable of running both my systems. But I like the idea of twin fuel pumps just in case.
Have you any idea of how much petrol you will flow when on the blower at WOT??
What size is your engine again?
topcatcustom
Post by topcatcustom »
If I get near my 300bhp target according to a little formula that Ian has it could be 60 gallons per hour on full whack- obviously won't be on it for that long at a time though! A red top will flow 45gph 6-8psi and I was going to put 2 in parallel "T"ing them together so will double the flow if need be on WOT, (also be a back up if one fails) and would also take a feed off for the nos, but I understand it may be better to have a seperate pump and feed for this now!
Return to “Nitrous Oxide Area ”
