OK, OK - I surrender. Lets recap on what is being fitted before we go off on all sorts of cams, bearings and new parts championship.
The COMPLETE engine is new - it is a complete unit - long engine - but having the intake upwards from the old engine re-installed.
So the sump, crank, shells, seals, block, heads, pistons, con-rods, valves, tappets, camshaft, rocker cams, timing gear, timing cover, small wiggly bit, other small wiggly bit and the screw down milk driven - non retrun - worm drive inserter flangifier are all new.
So the complete thing is needing tender loving care in some way to make sure I don't spend all this cash and time then destroy the Tw*t when I fire it up.
The complex bit for me was actually quite simple - a piddly little bush in the crank end for a manual input shaft but once out the "inertia drum" -Perry loves that - slidesin a treat and the only thing is making sure I don't screw up firing the damn thing back into life.
Got the Defib and a couple of small dressings ready if it needs it but hoping to just hear a few rattles for a couple of mins that die down and if I am lucky - some smells and a bit of "newness" smoke. No leaks or stuff.
We will see. So it is not just one or two new parts, the whole thing is bright and shiny - meaning it is certainly not at its optimum yet.
Doc
