Page 2 of 15
Posted: Thu Apr 17, 2008 8:11 am
What happens if you've got an automatic transmission?
Posted: Thu Apr 17, 2008 12:31 pm
If your name is Elliot you blow it up by putting too much power through it :lol: :lol:
Posted: Thu Apr 17, 2008 1:08 pm
by Eliot
ChrisJC wrote:What happens if you've got an automatic transmission?
Never tried, but going on what i have read, Its an issue. Ideally they want to do the run with a 1:1 ratio, which is typically 3rd on a GM box.
The problem is when you floor it, it will change back down to 2nd. So only thing i can think of, is to do the run on mine with it held in 2nd. I cant remember how fast mine goes in 2nd - i think about 75mph.
If i ever get my 4l80e installed, because its electronic - i can hold it in any gear regardless of anything - known as dyno mode. But that project is on the back burner at the moment, because my 700r4 is holding up to the abuse.
Posted: Thu Apr 17, 2008 1:12 pm
by mgbv8
That certainly looks like Martins place Elliot.
Posted: Thu Apr 17, 2008 7:52 pm
by csr
Stick me on the list too please.
Will have to get the Z28 taxed but that's ok.
and Tony will be there one way or another even if he's driving my truck.
Posted: Thu Apr 17, 2008 8:03 pm
by mgbv8
Mine is a 3 speed auto with a shifter kit. So I can select 1st 2nd or 3rd in manual mode and it wont upshift or kickdown.
Dont know what gear he was in last year when he did mine the first time.
I think it must have been 2nd. I suppose if you did it in 3rd you could disconnect the kickdown cable and vac modulator.
Posted: Thu Apr 17, 2008 9:10 pm
mgbv8 wrote: I suppose if you did it in 3rd you could disconnect the kickdown cable and vac modulator.
That's not a bad idea, shoud work with the ZF too. I think 3rd is 1:1 (although of course I would need to account for the transfer box too). In fact 4th would be better as there's a torque converter lockup.
Posted: Thu Apr 17, 2008 9:21 pm
by Coops
Bletchley / Milton Keynes Rolling road day 2008.
1. Perry Stephenson MGB V8
2. Tony Cooper Capri RV8
3. David Lush Capri RV8 (dependant on day)
4. Stuart Harrison Capri RV8 (if the thing ever starts! lol)
5. Reg D Capri V8
6. CSR Camaro Z28 or Chevy S10 truck.
Feel free to copy and paste your names on to the list with the next number chaps.
Posted: Thu Apr 17, 2008 9:42 pm
by ian.stewart
Is there a date for this??, I may be up for it if my car is back together,
Posted: Fri Apr 18, 2008 7:12 am
by Eliot
mgbv8 wrote:Mine is a 3 speed auto with a shifter kit. So I can select 1st 2nd or 3rd in manual mode and it wont upshift or kickdown.
On a TH350/400 the Vac modulator only controls line pressure and hence shift firmness. Removing the kickdown still wouldn't stop it changing down if it felt it needed to.
Besides mines a 700r4 and doesn't have either of those devices. I'm still up for having a try none the less.
Posted: Fri Apr 18, 2008 8:09 am
5. Reg D Capri V8
7. Chris Cowdery - Landie or Sherpa V8. (dependent on day)
Posted: Fri Apr 18, 2008 1:59 pm
by Eliot
5. Reg D Capri V8
8. Eliot - Dakar 4x4 assuming it will fit
Posted: Fri Apr 18, 2008 3:11 pm
by Ian Anderson
5. Reg D Capri V8
9. Ian Anderson GT40 RV8 JE Worked (Dependant on Day)
Posted: Fri Apr 18, 2008 7:57 pm
by mgbv8
Whayhay!!!
This is looking like it could be a fun day out chaps??
5. Reg D Capri V8
If I disconnect the modulator and kickdown cable on mine it will not kickdown at all. But my car is very light I suppose @ 1050kg all up with me and a tank full.
I had to fit the uprated TH350 adjustable modualtor to mine just to get it to upshift later in auto. Even now it upshifts way too early for quick fun so I shift it via the ratchet for road fun.
Posted: Wed Apr 23, 2008 9:15 pm
by tetlow
5. Reg D Capri V8
10. Dave Tetlow MGB V8
That is if its Aug or later and if it gets back from the states in one piece.
