MK2 Granada v8?
With a return style regulator, an efi pump will work just fine with carbs. I ran my old RV8 TT car with a Holley like this for years.katanaman wrote:depends on the age of the engine but generally its electric. An injection pump isnt suitable for use with carbs as its far too high a pressure. It is possible to regulate it but not worth the bother and to do right could cost more than buying a proper fuel pump.
If your car already has an efi pump etc, it would almost be silly not to use it.
My old RV8 was mounted using typical SD1 steel mounts, and a Ford rubber bobbin style rubber.
Round rubber, with a M10 stud sticking out either side, into the Granada subframe mounts.
It was very straightforward. I think there might have been a spacer or 2 in there somewhere too, but thats just a matter of trial and error.
Although it is worth mentioning....
The last mounts I used where as described. But instead of rubber bobbins, I got a bit of 2" steel bar, with a 10mm hole in the middle, and used it instead.
Basically bolting the engine solidly into the cradle. Saves a lot of hassle in terms of exhaust movement with soft mountings.
I also removed the rubber front subframe mounts, and replaced them with steel bar in a similar fashion, so the front suspension cradle is solid mounted to.
Its amazing how much rubber they use !!!!
beelzebubs
- Helpful or Confused
hokily dokily, here is my first post on this forum.
I have a Mk1 Granny Coupe, currently fitted with a rover v8, from the 10A engine code I have a manual SD1 lump, and the sump has been cut to fit the cross member. It has the Gmbox with the granny gearbox mounting spaced with four 2 inch spacers to get the hight right.
engine setting is paramount as the oil filter only clears the anti rollbar by less than 6mm, lift the engine any higher and the gear box will be hitting the ground one speed bumps.
My exhaust is cusom made for the job, the standard N/s manifold would be fine, its th O/s that has issues with the stearing.
The Su's fit under the bonnet just fine, but I couldnt be bothered with the hastles of petrol, so I binned the su manifold and fitted an injection manifold, filled in the injector holes, plugged up the cold start valve hole and I run solely on lpg.
Dependent on which fueling system you go with, make sure the vacuum take off for your box is of the correct diameter, or you will kill your gearbox with in a week, like I have.
You will also need to cut back your slam panel so you can recess the rad...apart from the above, its the best thing you can do to a mk1 or 2.....or any car needing an engine for that matter.
here is how it sounds, the second attempt at turning the key, first attemp was a disater.
http://www.granadaclassics.com/vroom.htm
