Rover 3.9 Injector CC's
ihatesissycars
Post by ihatesissycars »
What is the standard pressure that bosch injectors are rated at? I have some red topped ones, apparently 33lb p/h.
they are huge you probably wont be able to open and close them quick enough on a rover engine. The general flow data is usually at 3 bar 43 odd psi.
@ kokkolanpoika those are flowing way more than 3.9 injectors should LL part No ERR722
r2d2hp
Post by r2d2hp »
Hi Gavin,
From what I can tell these is not one standard, it seems to be injector specific.
kokkolanpoika, there must be something wrong with the way those injectors were tested. Even at 3bar I would think the flow would max out at abot 215cc/min
kokkolanpoika
Post by kokkolanpoika »
I have got full flow data available if you want it? If i found it?
My friend has got ford mustang 5.0gt 1991- He wash the injecktors same day as mine, (bacause it was cheaper wash over 16injectors than 8 ) but after mine, they flow 195cc/min. Book say 19lbs Witch is 193,8cc/min
I just notice that mine injectors have got also number 1244?
There is something for injectors.
http://www.pistonheads.com/gassing/topi ... &f=155&h=0
And i have got programmable injection system, engine produce about +300hp at least 280hp over 3years go. And injection time (duty cycle) is ~55% @full throtle 5500-6000rpm, and injectors firing batch mode.
Timo
ihatesissycars
katanaman wrote:they are huge you probably wont be able to open and close them quick enough on a rover engine. The general flow data is usually at 3 bar 43 odd psi.
Oh crap :roll:
GreenV8S
Post by GreenV8S »
In TVRs they're normally run at 2.5 bar, I assumed that was the standard pressure for the hotwire system.
kokkolanpoika
http://users.erols.com/srweiss/tableifc.htm
There is a lot of injectors.
I have got also 3,5 flapper injectors, part nro 280 150 105 they are 190cc @ 3bar, if that page is trusted?
Timo
