Can I pass 1990 emissions in UK with a carb?
r2d2hp
Re: Can I pass 1990 emissions in UK with a carb?
Post by r2d2hp »
There are several people that can map the 14CUX these days, have you spoken to http://www.powersperformance.co.uk/ to see if they can help
Any MegaSquirt can be triggered from the ignition - same as the Hotwire. But it would be silly not to have mapped ignition too. I'm intrigued about there not being space for a trigger wheel. An option is to fit one on the engine side of the inner pulley. You may have to change the pulley if it is flanged type, or have a custom trigger wheel made.
SimpleSimon
Post by SimpleSimon »
Ian this guy may be your man :wink: he can map the Lucas and worked with the guys that cracked the software lots of happy TVR customers using the CUX/Lucas that he tuned/re-mapped 8-) although like yourself I also run a single Lucas plenum and struggle 238 solid cam etc etc and also struggle a little with the below 2k RPM lurch/surging I have considered going 8 TB,s which I know will get round the plenum charge robbing/contamination issue that creates the low speed issue http://www.kitsandclassics.co.uk/ I dont recommend easy either he is a good guy
Aye I hear that people have cracked the 4CUX code
3 years back I moved to just outside Edinburgh. So not overly local ........ so simple up here may be better!
Or one last possibility, change it to a Ford mill, but in comparison to the lightened balanced unit I have it will be a plodder and probably mean a dif change too to get revs lower!
I've not done it, but read the software to re-map the Hotwire yourself was available?
Ian Anderson wrote: Tue Nov 26, 2019 6:37 am Aye I hear that people have cracked the 4CUX code
Trigger wheel should take up negligible space.
Go LS lol
stevieturbo wrote: Tue Nov 26, 2019 6:36 pm
Go LS lol
Oooooh LS the spawn Satan!
Incredible motors but not in a GT40.
Actually I once considered the V8 turbo diesel from a landy but thought a second time and saw the weight!
or the other option....and who'd ever think of it in such a car. V6 Ecoboost ! lol
Or a V8 Cyclone engine for a screamer!
v8 cyclone engine
ford steel 36-1 trigger wheel on an intermediate serp engine
