MX5 V8
Darkspeed
Post by Darkspeed »
southernd wrote:Thanks for the head info, that makes sense. The Vitesse do seem to have bigger valves etc, would they be classed as performance?
Valves are not bigger just a waisted stem as are most later heads - flow is still strangled by the throat - you can put all the valve you like, big as you can but without the throat / port being worked nothing gets in that cylinder :wink:
Good news is that the work to move the restriction is not very difficult but makes a huge difference.
Going to a big valve and making those work is a bit more involved and where it all starts getting costly. 225 can be had reasonably cheaply - 250+ start getting pricey and 300+ very ££££
4.5L V8 Ginetta G27
southernd
Post by southernd »
Thank you so much for your help, I really couldn't work out why the figures were so low for a sub 10k full rebuild.
It's been around 20 years since I was under the bonnet so I'm a bit rusty. Getting the heads ported is what I need to do?
I'm only looking for around 190bhp, I've owned much more powerful cars and been left wheel spinning at 90mph, I prefer usable power.
MX5 4.6 V8
Previous of many SD1's back in the day!
southernd
Post by southernd »
Just found an article for a 350i wedge, seems to hit the nail on the head:
I've just ported a set of heads to stage 1, which involved opening the throat diameter by about 1.5mm, cutting a 3 angle seat ,enlarging the bowl area and a back-cut on the inlet valves. This gave around about a 15% increase in flow on my flowbench, which in theory is good for an additional 40bhp*.
http://www.pistonheads.com/gassing/topic.asp?t=1274951
MX5 4.6 V8
Darkspeed
Post by Darkspeed »
A search on here will also bank a fair a mount of info.
A ported RV8 is like night and day compared to stock the heads are just that bad for flow.
southernd wrote:Just found an article for a 350i wedge, seems to hit the nail on the head:
4.5L V8 Ginetta G27
southernd
Post by southernd »
I'm really grateful for your help. I'll get the work done and report back :)
MX5 4.6 V8
