What carb do you have?Andrewrv8 wrote:I have another dizzy in my garage which I will take a look at, the link suggests running vac-less, particularly if using Eddy 500. Interesting, that could be the answer to the harsh vacuum from carb. The carb does need setting up properly (jets etc) as its still from the box, probably running lean. I will look into MSD for next engine, quite simple to hook up I understand. Damn, I had a lovely lightened flywheel hidden away
Ignition timing
These carbs are hardly ever (possibly never) set right out of the box for a Rover lump. Usually they are way too rich. They are worse on 4,6 then a 3.5. Most 3.5 lumps that Ive worked on needed the cruise leaning off around 8% most 4.6 lumps need the base setting for cruise leaning off between 12-16%. I guess the 4.6 pulls a higher vacuum on cruise compared to a 3.5 so this means that the jets 'see' a bigger depression and end up delievering more fuel, hence the carb needs to be set leaner in order to keep the air fuel ratio right.Andrewrv8 wrote:Eddy 500
This shows up at WOT too, the standard 95 secondaries are OK for a 3.5 but a 4.6 need much smaller secondaries to get the air fuel ratio around 12.5-12.8:1
My experiance of three rollings roads has not been very good, they just thrash the car on the rollers and tell you that everything is OK, they might if you are lucky check the WOT air fuel ratio, whether they would have the jets to change them is another matter!
I think that you are better off buying an air/fuel gauge such as an LC1, then learn how the carb works, after that you are in a position to do the work yourself.
I wrote this ages ago.....
http://how-to-build-a-pilgrim-sumo.wiki ... ing-system
I have changed my mind over a few things but most of it is correct, the main thing that I have changed my mind over this that the settings for a 3.5 are not the same ones required for a 4.6.
Kiwicar and Sidecar, I agree with both of you that I need to learn how to do it myself. This I will do. The link will help as it makes sense and does explain how it works. I've looked at buying an LC1 before and thought it looked complicated but I will invest in one. They are on ebay for £159 - is that about right?
Triumph TR7 V8 3.9efi
There are several makers of wideband O2 units. Innovate seem to get a lot of flack for reliability - but that could be just because they are the biggest maker. I believe they have a new model out which may be better.Andrewrv8 wrote:Kiwicar and Sidecar, I agree with both of you that I need to learn how to do it myself. This I will do. The link will help as it makes sense and does explain how it works. I've looked at buying an LC1 before and thought it looked complicated but I will invest in one. They are on ebay for £159 - is that about right?
There are a few setups that offer some small logging ability.sidecar wrote:I have an LC1, its OK but I must admit I have seen a much better system, it's name escapes me but it is basically the size of a 52mm dial, it stores data such as RPM and vac as well as the AFR, you can then download the data and work out what's going on over a nice cup of tea and a biscuit!
Handy for carb cars or where their ecu offers no logging.
You are right, it was an AEM gauge that I was thinking of...stevieturbo wrote:There are a few setups that offer some small logging ability.sidecar wrote:I have an LC1, its OK but I must admit I have seen a much better system, it's name escapes me but it is basically the size of a 52mm dial, it stores data such as RPM and vac as well as the AFR, you can then download the data and work out what's going on over a nice cup of tea and a biscuit!
http://aemelectronics.com/files/instruc ... 0Gauge.pdf
They seem to go for around 215 quid, not sure if that includes the actual probe but personally I think it's money well spent and much more cost effective than spending it on a RR session. In my opinion it can take a day or more to get the carb spot on and that's if you have all the jets and rods to hand. A whole day on a RR would cost a hell of a lot and unless the rollers can hold a steady but light load on the engine you can not setup the cruise using rollers anyway.
The calibration kits for these carbs are OK but I have quite often found that the best setup for an engine I've been working on was not even in the kit for the carb anyway! I end up modifying rods sometimes but it is tricky work, I use a rod holder that I made which I spin in my lathe, I then use very find wet and dry to thin the rods down. 1 thou off a rod can make a big difference, my rods are 69 thou on cruise (86 jet) and the car runs just fine at 14.5-15:1 AFR. One thou bigger (70 thou) and I can not even drive the car off my drive as its too lean!
AEM wideband kits are around £150
http://www.ebay.co.uk/itm/New-AEM-Digit ... 46139920be
And yes, they are an excellent tool to have in the car all the time.
the failsafe one that logs might be slightly more expensive.
Daytona sensors make some nice units too, and a good dual sensor/display which also logs. Handy for monitoring each bank, but whether the cost justifies the unit is another matter
http://www.daytona-sensors.com/WEGO4.html
