Cracked Blocks!
Eliot wrote:Where as these cheap LS engines mike, as i never seem to find any.kiwicar wrote:Hi
So why not buy an LS* chevy, they cost less (a whole long engine is about the same as getting a rover block top hat linered) produce about twice the power as standard, can be cheaply tuned, are smaller than the rover and as they have a modern combustion chamber and modern valve gear they can easily get through the emissions.
best regards
Big Tone
www.cobratone.co.uk
www.cobratone.co.uk
I love the website Chris
Especially the Food For Tossers section. Very funny mate.
Heres one I always remember because I bought these when they came out
A mate did that to his race engine. He went to a drill supplier and bought a rifle barrel drill in the size he wanted and ran it into the gallery. He said that quite a bit of material came out, too. He then tapped the holes in the rear of the block and fitted screw-in plugs with Loctite. I think he did the holes to the journals, too just for uniformity.
kiwicar wrote:Hi
a 300bhp rover however you do it is going to be a lot more than £2K.
Unless you buy the one on Ebay at the mo ??
I've seen this lump make 312hp on the carb only
