Page 2 of 2
Posted: Mon Sep 15, 2014 5:40 am
by unstable load
You should continue fitting the Megajolt, then. It certainly will help spark strength and control for you.
Posted: Mon Sep 15, 2014 7:23 am
by sowen
unstable load wrote:You should continue fitting the Megajolt, then. It certainly will help spark strength and control for you.
It's the old setup I had on my carb'd Land Rover, ran very well. The egajolt wiring is already fitted into the SD1, and I had it briefly running on the carbs before taking them off to fit the efi. I need to make a new coilpack mounting bracket, new ignition leads and some clever wiring to retain the rev counter and efi trigger. I have a selection of diodes and stuff I bought specially to do the job, but not sat down and tried soldering them together yet!
Posted: Tue Sep 16, 2014 6:30 am
by unstable load
Well, if it's already paid for, then even more reason to continue.
