3.9 RV8 Twin Turbo MGB - Updated 10th March '09
chodjinn
Post by chodjinn »
bonnet bulges have gone. I'm using a fibreglass MGC replica bonnet.
Inner wings have pretty much all been removed, with strengthening bars instead. No pics of exhaust yet - but they're huge side exit monsters!
chodjinn
Post by chodjinn »
Just acquired a bunch of spanky parts for my next engine build; Group A conrods, Cosworth forged pistons, Group A adjustable rockers and some custom rocker covers 8)
Post by CastleMGBV8 »
Ollie
Which Cosworth pistons are they as I couldn't find anything suitable when I last looked,
What bore size, small end/gudgeon pin size and compression height?
Would love to know, and how much are they?
chodjinn
Post by chodjinn »
Hi Kevin,
The pistons that I have are 3.5l bore, with standard 3.5 grudgeon pins as they are currently on some standard rods. I only have 7 of them though so I'm gonna get in touch with cosworth and see if I can get an 8th one to match, but for the price I paid it would have been stupid not to they we're practically free. The part number is PA0470/1 and I believe they are about 8:1 comp ratio. I've got another set of high comp ones that came with the group a rods I have just got, part number PA0753/1, which I have for sale in the classifieds as they're to high a comp ratio for me and the guy wanted to sell them as a set with the rods.
The low comp ones have standard grudgeon pins, but the high comp ones have floating pins with cir-clips. I already have a newly balanced crank, so I'm just a piston short of the rotating assembly, planning on building a super strong 3.5l and whacking a hell of a lot more boost through than the 5-6psi I'm running in the 3.9 I have at the moment. Have a small matter of a block to buy tho first! :roll:
Thanks Ollie, I thought they were for the 3.9 large bore block as when I was looking for a full flat piston top for my new engine I could not find any without having them specialy made which would have been cost prohibitive.
The nearest I could get was a set of Keith Black Hypereutectic cast pistons with 5cc cutouts which I got from Summit in the states for only £180.00 ! They also do a dished piston which would give a lower compression ratio with a bore size of 94.89mm so you need to have the block bored and honed and you need a set of Chevy con rods at £250.00 to match the larger gudgeon pin.
Hopefully my new 4.35 engine is going into the car in the next few days.
chodjinn
Post by chodjinn »
I got mixed up, the floating pins dont have cir-clips in them :roll:
Floating pins shoulds have circlips or they they will move and contact the bores. The small ends should also be bushed.
chodjinn
Post by chodjinn »
Well I'm well confused now. Looking at the low comp pistons, they have standard rods and use circlips - the pistons even have a little grove in them for the clips.
The high comp ones don't have circlips or any groove for them, and using the group A rods, the grudgeons do move a bit but seem well secure?
All the rods are bushed, yeah.
I believe you then need teflon buttons at either end of the pin
The teflon stuff will not score the bore if / when the pin moves
chodjinn
Post by chodjinn »
Just spoke to a bloke at Cosworth, not looking good for finding a replacement piston . . . :evil:
If you are using standard rods which have interference fit pin, then no circlips should be used.
If the rod is bushed for a floating pin, then circlips or buttons must be used.
chodjinn
MGB 3.9 RV8 Twin Turbo - New pics
Post by chodjinn »
Ok some updated pics;
Trigger wheel and VR sensor
Nearside turbo;
Home made battery box, mounted to original MGB battery access plate;
Engine bay mock up, without intercooler/turbo pipes (not ordered them yet!);
Inside boot (old photo);
Tight squeeze !!!!....but stronger crank sensor bracket required. That will vibrate.
chodjinn
Post by chodjinn »
you're telling me mate! I've changed the position of a few thinsg at the front since the lat photos, namely the oil breather and oil filter. And that's not including the 6 pieces of pipework and custom plenum!
Bracket was made from 3mm alu, I've got some 4mm mild steel that should be ok then, will use the alu bracket as a template. Took me over an hour to make that and get it in position right! Typical :lol:
god i gota get my arse in gear and do something about turboing my ole gal.
nice install mate,
