stevieturbo wrote:You shim either side of the bearings to move the crownwheel from side to side
Yep!!
Simple as that
And with a mate nearby who has a precision grinder, the selection of shims I have can be altered however I want ?
BUT!
That will not be required now. Kiwi came round today and we hauled the rear axle out of the MGB and fitted the spool into my actual diff case with the shims I have already machined and it dropped in perfectly. With the bearing caps fitted the spool has no sideways play and can be turned with a feather light touch
So it will be 3mm off the crown wheel and 5mm off the spool flange, then my mate can get busy with re drilling the spool flange to take the crown wheel bolts.
This is all getting quite exciting now !
The drive shafts are now on their way via UPS so I'm hoping to see them by the end of next week? Fingers crossed
